Datasheet Texas Instruments CDCE906PWRG4 — Даташит
СерияCDCE906
МодельCDCE906PWRG4
Программируемый 3-PLL тактовый синтезатор/умножитель/делитель 20-TSSOP от 0 до 70
Programmable 3-PLL Clock Synthesizer / Multiplier/Divider datasheet
PDF, 1.7 Мб, Версия: H, Файл опубликован: 11 дек 2007
Pin20
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)2.20 | 1ku
Divider RatioUniversal
FunctionClock Synthesizer
Clock Multiplier
Clock Divider
Input LevelCrystal
LVCMOS
Differential
Jitter-Peak to Peak(P-P) or Cycle to Cycle(C-C)60 ps
Output Frequency(Max)(MHz)167
Output LevelLVCMOS
Output Skew(ps)150
Package GroupTSSOP
Package Size: mm2:W x L (PKG)20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
Special FeaturesIntegrated EEPROM
Multiplier/Divider
Spread Spectrum Clocking (SSC)
VCC(V)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: CDCE906-706PROGEVM
    CDCE906 and CDCE706 programmable EVM
  • Evaluation Modules & Boards: CDCE906-706PERFEVM
    CDCE906 and CDCE706 EVM
  • Recommended Terminations for the Differential Inputs of CDCE906/CDCE706
    PDF, 84 Кб, Файл опубликован: 10 авг 2006
    This application report describes how differential signals (LVDS, LVPECL, and HSTL) can be connected to CDCE706/CDCE906 differential inputs directly. The wide common-mode voltage and smaller swing required make the devices so versatile that they can receive any signal without any complicated coupling and biasing circuits.
  • CDCx706/x906 Termination and Signal Integrity Guidelines (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 28 ноя 2007
    This application report shows and evaluates different schemes for the CDCE706, CDCE906, CDC706, and CDC906. Guidelines for optimizing the series termination are discussed. Additionally, this report describes how the CDCx706/x906 family can be used to drive 1.8-V clock inputs.
  • High Speed Layout Guidelines (Rev. A)
    PDF, 762 Кб, Версия: A, Файл опубликован: 8 авг 2017
    Thisapplicationreportaddresseshigh-speedsignals,suchas clocksignalsand theirrouting,and givesdesignersa reviewof the importantcoherences.Withsomesimplerules,electromagneticinterferenceproblemscan be minimizedwithoutusingcomplicatedformulasand expensivesimulationtools.Section1givesa shortintroductionto theory,whileSection
  • Clock Recommendations for the DM643x EVM
    PDF, 121 Кб, Файл опубликован: 29 ноя 2006
    The DM643x evaluation module (EVM) requires several clock frequencies to run the system properly. The current clocking proposal of the low-cost EVM consists of the VCXO chip PI6CX100-27W, the PLL chip PLL1705, several bus drivers, and a few oscillaors and crystals. This application report discusses several optimized clocking proposals with the Texas Instruments new clock drivers and recommends a m
  • Troubleshooting I2C Bus Protocol
    PDF, 184 Кб, Файл опубликован: 19 окт 2009
    When using the I2Cв„ў bus protocol, the designer must ensure that the hardware complies with the I2C standard. This application report describes the I2C protocol and provides guidelines on debugging a missing acknowledgment, selecting the pullup resistors, or meeting the maximum capacitance load of an I2C bus. A conflict occurs if devices sharing the I2C bus have the same slave address. This
Серия: CDCE906 (4)
  • Semiconductors > Clock and Timing > Clock Generators > Spread-Spectrum Clocks
На английском языке: Datasheet Texas Instruments CDCE906PWRG4
