Datasheet Texas Instruments CDCLVP110MVFRG4 — Даташит
СерияCDCLVP110
МодельCDCLVP110MVFRG4
1:10 Драйвер часов от LVPECL/HSTL до LVPECL 32-LQFP от -40 до 85
Low-Voltage 1:10 LVPECL/HSTL With Selectable Input Clock Driver datasheet
PDF, 653 Кб, Версия: D, Файл опубликован: 11 янв 2011
Pin32
Package TypeVF
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаCDCLVP110
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).8
Max Height (мм)1.6
Additive RMS Jitter(Typ)300 fs
Input Frequency(Max)3500 МГц
Input LevelHSTL,LVPECL
Количество выходов10
Output Frequency(Max)3500 МГц
Output LevelLVPECL
Package GroupLQFP
Package Size: mm2:W x L32LQFP: 81 mm2: 9 x 9(LQFP) PKG
VCC2.5,3.3 В
VCC Out2.5,3.3 В
  • Advantage of Using TI's Lowest Jitter Differential Clock Buffer
    PDF, 221 Кб, Файл опубликован: 20 авг 2003
    Advantage of Using TI's Lowest Jitter Differential Clock Buffer at SONET Speed 622.08 MHz
  • PCB Layout Guidelines for CDCLVP110
    PDF, 70 Кб, Файл опубликован: 12 июн 2002
    This application note describes various electrical and thermal performance considerations for TI's CDCLVP110. In addition, it provides recommendations for PCB layout as well as optimizing power consumption in a real system application. Finally, it shows examples of how to estimate the worst case chip temperature.
  • Clocking Design Guidelines: Unused Pins
    PDF, 158 Кб, Файл опубликован: 19 ноя 2015
  • DC-Coupling Between Differential LVPECL, LVDS, HSTL, and CML
    PDF, 135 Кб, Файл опубликован: 19 фев 2003
  • AC Coupling Between Differential LVPECL, LVDS, HSTL and CML (Rev. C)
    PDF, 417 Кб, Версия: C, Файл опубликован: 17 окт 2007
    This report provides a quick reference of ac-coupling techniques for interfacing between different logic levels. The four differential signaling levels found in this reportare low-voltage positive-referenced emitter coupled logic (LVPECL), low-voltage differential signals (LVDS), high-speed transceiver logic (HSTL), and current-modelogic (CML). From these four differential signaling levels, 16
  • Semiconductors > Clock and Timing > Clock Buffers > Differential
На английском языке: Datasheet Texas Instruments CDCLVP110MVFRG4
