Datasheet Texas Instruments CDCM61001RHBT — Даташит
СерияCDCM61001
МодельCDCM61001RHBT
Тактовый генератор с тактовым сигналом 1:1 со сверхнизким джиттером 32-VQFN
One Output, Integrated VCO, Low-Jitter Clock Generator.. datasheet
PDF, 948 Кб, Версия: F, Файл опубликован: 2 июн 2011
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаCDCM61001
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Input LevelCrystal,LVCMOS
Количество выходов1
Output Frequency(Max)683.28 МГц
Output Frequency(Min)43.75 МГц
Output LevelLVPECL,LVDS,LVCMOS
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
ProgrammabilityPin configuration
Special FeaturesPin Programming
VCC Core3.3 В
VCC Out3.3 В
  • Evaluation Modules & Boards: CDCM6100XEVM
    CDCM61004/CDCM61002/CDCM61001 Evaluation Module
  • Fibre Channel and SAN Clock Generation Using the CDCM6100x
    PDF, 322 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in a Fibre Channel application as a clock distributor and clock synthesizer along with measured jitter performance results.
  • Using LVCMOS Input to the CDCM6100x
    PDF, 66 Кб, Файл опубликован: 23 май 2010
    This application report is a general guide for using LVCMOS inputs to the CDCM6100x series of ultra-low jitter clock generators from Texas Instruments. This document explains the basic connectivity of LVCMOS inputs to the CDCM6100x and recommends several methods for using the device that ensure proper operation.
  • Ethernet Clock Generation Using the CDCM6100x
    PDF, 454 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in an Ethernet LAN and WAN application as a clock distributor and clock synthesizer along with measured jitter performance results.
  • TI Powers Altera's Arria II GX FPGA Development Kit
    PDF, 596 Кб, Файл опубликован: 29 сен 2009
Серия: CDCM61001 (3)
  • Semiconductors > Clock and Timing > Clock Generators > General Purpose
На английском языке: Datasheet Texas Instruments CDCM61001RHBT
