Datasheet Texas Instruments CDCM61001 — Даташит
СерияCDCM61001
1:1 Кристаллический тактовый генератор со сверхнизким джиттером
One Output, Integrated VCO, Low-Jitter Clock Generator.. datasheet
PDF, 948 Кб, Версия: F, Файл опубликован: 2 июн 2011
CDCM61001RHBRCDCM61001RHBR/2801CDCM61001RHBT
Статус продуктаВ производствеВ производствеВ производстве
Доступность образцов у производителяНетДаНет
N123
Pin323232
Package TypeRHBRHBRHB
Industry STD TermVQFNVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-NS-PQFP-N
Package QTY30003000250
CarrierLARGE T&RLARGE T&RSMALL T&R
Маркировка6100161001CDCM
Width (мм)555
Length (мм)555
Thickness (мм).9.9.9
Pitch (мм).5.5.5
Max Height (мм)111
Parameters / ModelsCDCM61001RHBR
CDCM61001RHBR
CDCM61001RHBR/2801
CDCM61001RHBR/2801
CDCM61001RHBT
CDCM61001RHBT
Input LevelCrystal,LVCMOSCrystal,LVCMOSCrystal,LVCMOS
Количество выходов111
Output Frequency(Max), МГц683.28683.28683.28
Output Frequency(Min), МГц43.7543.7543.75
Output LevelLVPECL,LVDS,LVCMOSLVPECL,LVDS,LVCMOSLVPECL,LVDS,LVCMOS
Package GroupVQFNVQFNVQFN
Package Size: mm2:W x L, PKG32VQFN: 25 mm2: 5 x 5(VQFN)32VQFN: 25 mm2: 5 x 5(VQFN)32VQFN: 25 mm2: 5 x 5(VQFN)
ProgrammabilityPin configurationPin configurationPin configuration
Special FeaturesPin ProgrammingPin ProgrammingPin Programming
VCC Core, В3.33.33.3
VCC Out, В3.33.33.3
  • Fibre Channel and SAN Clock Generation Using the CDCM6100x
    PDF, 322 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in a Fibre Channel application as a clock distributor and clock synthesizer along with measured jitter performance results.
  • Using LVCMOS Input to the CDCM6100x
    PDF, 66 Кб, Файл опубликован: 23 май 2010
    This application report is a general guide for using LVCMOS inputs to the CDCM6100x series of ultra-low jitter clock generators from Texas Instruments. This document explains the basic connectivity of LVCMOS inputs to the CDCM6100x and recommends several methods for using the device that ensure proper operation.
  • Ethernet Clock Generation Using the CDCM6100x
    PDF, 454 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in an Ethernet LAN and WAN application as a clock distributor and clock synthesizer along with measured jitter performance results.
  • TI Powers Altera's Arria II GX FPGA Development Kit
    PDF, 596 Кб, Файл опубликован: 29 сен 2009
  • Semiconductors> Clock and Timing> Clock Generators> General Purpose
На английском языке: Datasheet Texas Instruments CDCM61001
