Datasheet Texas Instruments CDCP1803RTHR — Даташит
СерияCDCP1803
МодельCDCP1803RTHR
1:3 LVPECL Clock Buffer with Programmable Divider, CDCP1803 datasheet
PDF, 873 Кб, Версия: F, Файл опубликован: 4 дек 2013
Pin24
Package TypeRTH
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Width (мм)4
Length (мм)4
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Additive RMS Jitter(Typ)(fs)150
Approx. Price (US$)3.15 | 1ku
Input Frequency(Max)(MHz)800
Input LevelLVPECL
No. of Outputs3
Operating Temperature Range(C)-40 to 85
Output Frequency(Max)(MHz)800
Output LevelLVPECL
Package GroupVQFN
Package Size: mm2:W x L (PKG)24VQFN: 16 mm2: 4 x 4(VQFN)
VCC Out(V)3.3
VCC(V)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: ADS6143EVM
    ADS6143 Evaluation Module
  • Evaluation Modules & Boards: ADS6123EVM
    ADS6123 Evaluation Module
  • Evaluation Modules & Boards: ADS6125EVM
    ADS6125 Evaluation Module
  • Evaluation Modules & Boards: ADS6124EVM
    ADS6124 Evaluation Module
  • Evaluation Modules & Boards: ADS6122EVM
    ADS6122 Evaluation Module
  • Evaluation Modules & Boards: ADS6144EVM
    ADS6144 Evaluation Module
  • Evaluation Modules & Boards: ADS6142EVM
    ADS6142 Evaluation Module
  • Dual Purposes: Data Buffer, The Other Face of CDCP1803
    PDF, 462 Кб, Файл опубликован: 13 авг 2004
    The CDCP1803 is a clock driver by design, but can be used as a data buffer. The CDCP1803 performance as a data buffer is demonstrated both in terms of the bit errorrate (BER) and eye pattern diagrams. The CDCP1803 is tested over several signaling rates and different PRBS patterns.
  • Semiconductors > Clock and Timing > Clock Buffers > Dividers
На английском языке: Datasheet Texas Instruments CDCP1803RTHR
