Datasheet Texas Instruments CDCS503PWR — Даташит
| Серия | CDCS503 |
| Модель | CDCS503PWR |
Буфер тактовой частоты/умножитель тактовой частоты с дополнительным SSC 8-TSSOP от -40 до 85
Clock Buffer / Clock Multiplier with optional SSC datasheet
PDF, 952 Кб, Файл опубликован: 23 мар 2009
Купить CDCS503PWR на РадиоЛоцман.Цены — от 18 до 162 ₽39 предложений от 17 поставщиков Микросхема Тактовый амортизатор, драйвер, схема фазовой автоподстройки, Clock Buffer/Clock Multiplier -40℃ to 85℃ 8Pin TSSOP T/R | |||
| CDCS503PWR Texas Instruments | от 18 ₽ | ||
| CDCS503PWR Texas Instruments | 96 ₽ | ||
| CDCS503PWR Texas Instruments | 113 ₽ | ||
| CDCS503PWR | по запросу | ||
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | CS503 |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Function | Spread Spectrum Clock |
| Input Level | LVCMOS |
| Output Frequency(Max) | 108 МГц |
| Output Frequency(Min) | 8 МГц |
| Output Level | LVCMOS |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG |
| Rating | Catalog |
| Special Features | 3.3V Vcc/Vdd,Spread Spectrum Clocking (SSC) |
| VCC | 3.3 В |
- Spread Spectrum Clocking Using the CDCS502/503PDF, 181 Кб, Файл опубликован: 19 авг 2009
Spread Spectrum Clocking (SSC) is a common way to overcome EMI issues. This application report provides an overall view of the principles behind SSC. It also includes practical considerations about why, when, and how to use the CDCS502 and CDCS503 SSC clock generator. When SSC is included early in the design process, it can reduce the redesign cycle and drastically decrease the cost of new product
- Semiconductors > Clock and Timing > Clock Generators > Spread-Spectrum Clocks
