Datasheet Texas Instruments CDCV850DGGG4 — Даташит
СерияCDCV850
МодельCDCV850DGGG4
Дифференциальный тактовый драйвер с фазовой автоподстройкой напряжения 2,5 В и 2-линейным последовательным интерфейсом 48-TSSOP от -40 до 85
2.5-V Phase Lock Loop Clock Driver With 2-Line Serial Interface datasheet
PDF, 798 Кб, Версия: D, Файл опубликован: 10 апр 2013
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY40
МаркировкаCDCV850
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Absolute Jitter (Peak-to-Peak Cycle or Period Jitter)30 ps
Количество выходов10
Operating Frequency Range(Max)140 МГц
Operating Frequency Range(Min)60 МГц
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
VCC2.5 В
t(phase error)180 ps
tsk(o)75 ps
  • HSTL Clock Buffer Using the CDCV850
    PDF, 35 Кб, Файл опубликован: 15 июл 2002
    The demand for driving 1.5-V HSTL signals for high-integrated and low-voltage digital logic is increasing. Most current systems use LVDS, LVPECL, or 2.5-V LVCMOSsignaling levels. Therefore, a solution is needed to convert these clock signals into HSTL signal swing.The purpose this report is to show how to generate an HSTL compliant clock signal using the CDCV850. This clock buffer accepts LV
  • Using CDC857/CDCV850 toTransform Single-End CLK Signal Into Differential Output
    PDF, 437 Кб, Файл опубликован: 27 сен 2000
    The CDC857 and the CDCV850 devices are PLL-based differential clock drivers with a maximum operational frequency of 167 MHz. These devices have been designed to support a double-data-rate (DDR) specification and, therefore, they have higher immunity against incoupling common mode noise. However, they require a differential clock input signal.This report shows (a) how to convert a single ended cl
  • Semiconductors > Clock and Timing > Clock Buffers > Zero Delay Buffers
На английском языке: Datasheet Texas Instruments CDCV850DGGG4
