Datasheet Texas Instruments 5962-9221804MRA — Даташит
| Серия | CY54FCT374T |
| Модель | 5962-9221804MRA |
Восьмеричные регистры типа D с выходами с 3 состояниями 20-CDIP от -55 до 125
8-Bit Registers With 3-State Outputs datasheet
PDF, 692 Кб, Версия: A, Файл опубликован: 1 окт 2001
Купить 5962-9221804MRA на РадиоЛоцман.Цены — от 336 до 3 333 ₽13 предложений от 13 поставщиков Octal D-type registers with 3-state outputs 20-CDIP -55 to 125 | |||
| 5962-9221804MRA Renesas | 336 ₽ | ||
| 5962-9221804MRA Texas Instruments | 1 247 ₽ | ||
| 5962-9221804MRA Texas Instruments | 3 288 ₽ | ||
| 5962-9221804MRA Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 6.92 |
| Length (мм) | 24.2 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
Серия: CY54FCT374T (10)
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629221804MRA, 5962 9221804MRA
