Datasheet Texas Instruments CY54FCT573T — Даташит
Серия | CY54FCT573T |
Восьмеричные прозрачные защелки D-типа с выходами с 3 состояниями
8-Bit Latches With 3-State Outputs datasheet
PDF, 679 Кб, Файл опубликован: 1 окт 2001
5962-9223801MRA | 5962-9223802M2A | CY54FCT573ATLMB | |
Статус продукта | В производстве | В производстве | В производстве |
Доступность образцов у производителя | Нет | Нет | Нет |
N | 1 | 2 | 3 |
Pin | 20 | 20 | 20 |
Package Type | J | FK | FK |
Industry STD Term | CDIP | LCCC | LCCC |
JEDEC Code | R-GDIP-T | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Width (мм) | 6.92 | 8.89 | 8.89 |
Length (мм) | 24.2 | 8.89 | 8.89 |
Thickness (мм) | 4.57 | 1.83 | 1.83 |
Pitch (мм) | 2.54 | 1.27 | 1.27 |
Max Height (мм) | 5.08 | 2.03 | 2.03 |
Маркировка | 573ATLMB |
RoHS | See ti.com | See ti.com | See ti.com |
- Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
Серия: CY54FCT573T (3)
- Semiconductors> Space & High Reliability> Logic Products> Flip-Flop/Latch/Registers
