Datasheet Texas Instruments DAC38RF96IAAV — Даташит
СерияDAC38RF96
МодельDAC38RF96IAAV
Двухканальный, 14-разрядный, 9-GSPS, интерполяционный 12x-24x, 9 ГГц, цифро-аналоговый преобразователь (ЦАП) GSM с ФАПЧ 144-FCBGA от -40 до 85
DAC38RFxx Dual-Channel, Single-Ended, 14-Bit, 6- and 9-GSPS, RF-Sampling DAC With JESD204B Interface and On-Chip GSM PLL datasheet
PDF, 3.5 Мб, Версия: B, Файл опубликован: 31 июл 2017
Pin144
Package TypeAAV
Industry STD TermFCBGA
JEDEC CodeS-PBGA-N
Package QTY168
CarrierJEDEC TRAY (5+1)
МаркировкаDAC38RF96I
Width (мм)10
Length (мм)10
Thickness (мм)1.45
Pitch (мм).8
Max Height (мм)1.94
АрхитектураCurrent Source
DAC Channels2
InterfaceJESD204B
Interpolation12x,16x,18x,20x,24x
Package GroupFCBGA
Package Size: mm2:W x LSee datasheet (FCBGA) PKG
Power Consumption(Typ)3800 mW
Разрешение14 Bits
SFDR72 дБ
Sample / Update Rate9000 MSPS
  • Evaluation Modules & Boards: DAC38RF86EVM
    DAC38RF86 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 9 GHz GSM PLL DAC Evaluation Module
  • DAC38RF8x Test Modes
    PDF, 3.0 Мб, Файл опубликован: 25 июл 2017
    The DAC38RF8x family of devices comes equipped with multiple test modes to assist users in verifying systems in rapid prototyping situations. This application report covers two of the available tests, the pseudorandom binary-sequence test and JESD204B short pattern test, in detail using the TI DAC38RF8xEVM and TSW14J56EVM capture card.
  • Quick-Start Methods in Simulating the DAC38RF8x Input/Output Buffer Information
    PDF, 600 Кб, Файл опубликован: 2 авг 2017
    Input/output Buffer Information Specification (IBIS) models are used to simulate digital electrical interfaces.These models can be categorized into two main categories: traditional and algorithmic modeling interface(AMI). AMI is typically used for SerDes channel simulation, and is different from the traditional IBIS model,which is the focus of this document. These models are simple ASCII tex
  • Eye Scan Testing with the DAC38RFxx
    PDF, 3.6 Мб, Файл опубликован: 10 авг 2017
    The DAC38RFxx family of devices comes equipped with the capability to generate eye diagrams by usinging JTAG communication with the DAC38RF8x eye scan GUI software. By running this software, users can generate eye diagrams to compare with the JESD204B standard eye mask requirements, and verify signal integrity performance of the SerDes link between DAC and FPGA/ASIC. This application report descri
Серия: DAC38RF96 (2)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC38RF96IAAV
