Datasheet Texas Instruments DDC118IRTCR — Даташит
СерияDDC118
МодельDDC118IRTCR
Восьмеричный 20-битный аналого-цифровой преобразователь с токовым входом 48-VQFN от -40 до 85
Octal Current Input, 20-Bit Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 1 апр 2009
Pin48
Package TypeRTC
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаDDC118
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм).9
# Input Channels8
InterfaceSPI
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Разрешение20 Bits
Sample Rate (max)3.125kSPS SPS
Special FeaturesComputed Tomography (CT)
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
Серия: DDC118 (3)
  • Semiconductors > Sensing Products > Photodiode Sensing
На английском языке: Datasheet Texas Instruments DDC118IRTCR
