Datasheet Texas Instruments DDC118IRTCTG4 — Даташит
Серия | DDC118 |
Модель | DDC118IRTCTG4 |
Восьмеричный 20-битный аналого-цифровой преобразователь с токовым входом 48-VQFN от -40 до 85
Octal Current Input, 20-Bit Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 1 апр 2009
Pin | 48 |
Package Type | RTC |
Industry STD Term | VQFNP |
JEDEC Code | S-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | DDC118 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | .9 |
Mechanical Data | Скачать |
# Input Channels | 8 |
Interface | SPI |
Package Group | VQFN |
Package Size: mm2:W x L | 48VQFN: 49 mm2: 7 x 7(VQFN) PKG |
Rating | Catalog |
Разрешение | 20 Bits |
Sample Rate (max) | 3.125kSPS SPS |
Special Features | Computed Tomography (CT) |
- Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma ConvertersPDF, 105 Кб, Файл опубликован: 27 сен 2000
Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
Серия: DDC118 (3)
- DDC118IRTCR DDC118IRTCT DDC118IRTCTG4
- Semiconductors > Sensing Products > Photodiode Sensing
