Datasheet Texas Instruments DLP5500AFYA — Даташит
Серия | DLP5500 |
Модель | DLP5500AFYA |
DLPВ® 0.55 XGA DMD 149-CPGA
DLP5500 DLPВ® 0.55 XGA Series 450 DMD datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 26 май 2015
8 предложений от 8 поставщиков IC DIG MICROMIRROR DEV 149CPGA. Digital Micromirror Device (DMD) 149-CPGA (22.3x32.2). Specialized ICs | |||
DLP5500AFYA Texas Instruments | 65 ₽ | ||
DLP5500AFYA Texas Instruments | по запросу | ||
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 149 |
Package Type | FYA |
Industry STD Term | CPGA |
JEDEC Code | R-CLGA-N |
Width (мм) | 32.2 |
Length (мм) | 22.3 |
Thickness (мм) | 4 |
Pitch (мм) | 1.27 |
Max Height (мм) | 5.4 |
Mechanical Data | Скачать |
Approx. Price (US$) | 403.20 | 1ku |
Chipset Family | DLP5500 |
Component Type | DMD |
Illumination Wavelength Range(nm) | 420-700 |
Max Display Resolution | XGA |
Max Pattern Rate, 8-bit(Hz) | 500 |
Max Pattern Rate, Binary(Hz) | 5 000 |
Max Pixel Data Rate(Gbps) | 3.9 |
Micromirror Array Orientation | Orthogonal |
Micromirror Array Size | 1024x768 |
Micromirror Driver Support | External |
Micromirror Pitch(um) | 10.8 |
Package Group | CPGA |
Power Consumption, Typical(mW) | 1700 |
Thermal Dissipation (В°C/W) | 0.6 |
RoHS | Не совместим |
- DLPВ® Series-450 DMD and System Mounting ConceptsPDF, 5.0 Мб, Файл опубликован: 18 июн 2010
As an aid to the successful first time utilization and implementation of the DLP5500, Series-450 DMD, thisapplication report addresses the following topics:TerminologySpecification and design details of a Series-450 DMDSystem mounting concepts for a Series-450 DMD, including key attributes and important applicationdesign considerationsSockets for use - Series 4xx DMD Handling SpecificationPDF, 55 Кб, Файл опубликован: 18 июн 2010
PURPOSEDefine the minimum requirements for DMD HandlingEstablish precautions to protect the DMD from Electrostatic Discharge (ESD)Establish precautions to protect the DMD’s glass and electrical contacts - Series 4xx DMD Cleaning ProcedurePDF, 41 Кб, Файл опубликован: 18 июн 2010
Provide correct and consistent methods for cleaning the glass of the DMD in such a way that theanti-reflective coatings on the glass surface are not damaged. - DLP Light Commander Kit: Extending the Connection Between the Controller and DMDPDF, 387 Кб, Файл опубликован: 1 дек 2011
The DLP LightCommander development kit was introduced as a platform for exploring the possibilities ofDLP technology, and facilitating the development of customer DLP applications. The LightCommander ismodular in concept, allowing for a certain amount of flexibility in the arrangement of the components andmodifications to the default setup.One of the configurations often requested involv - DLP LightCommander API Reference Manual (Rev. C)PDF, 247 Кб, Версия: C, Файл опубликован: 13 май 2013
- DLP LightCommander API Application Report (Rev. C)PDF, 928 Кб, Версия: C, Файл опубликован: 5 июн 2013
- Using DLPВ® Development Kits for 3D Optical Metrology SystemsPDF, 590 Кб, Файл опубликован: 13 май 2011
Structured light is the process of projecting known patterns of pixels onto an object. When combined witha synchronized camera, a structured light pattern generator can enable highly accurate 3D opticalmeasurements.This application note presents the operating theory of structured light systems, as well as the keycomponents and design considerations. Special attention is given to hardware - Geometric Optics for DLPВ®PDF, 714 Кб, Файл опубликован: 5 дек 2013
DLP3000, DLP4500, DLP5500, DLP7000, DLP9500, DLPВ® LightCrafterв„ў, DLPВ® LightCrafter 4500в„ў Geometric Optics for DLP - Wavelength Transmittance Considerations for DLP DMD Windows (Rev. C)PDF, 771 Кб, Версия: C, Файл опубликован: 21 мар 2014
Wavelength Transmittance Considerations for DLP DMD Windows /DLP/Application_Reports/DLPA031/DLPS500 - DMD 101: Introduction to Digital Micromirror Device (DMD) Technology (Rev. A)PDF, 3.9 Мб, Версия: A, Файл опубликован: 7 окт 2013
DMD 101: Introduction to Digital Micromirror Device (DMD) Technology - Mounting Hardware and Quick Reference Guide for DLPВ® Advanced Light Control DMDsPDF, 383 Кб, Файл опубликован: 20 июл 2016
Серия: DLP5500 (2)
- DLP5500AFYA DLP5500BFYA
- Semiconductors > DLP Products > Advanced Light Control > Pattern Rate (<8 kHz)
