Datasheet Texas Instruments DLP5500 — Даташит
СерияDLP5500
DLPВ® 0.55 XGA DMD
DLP5500 DLPВ® 0.55 XGA Series 450 DMD datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 26 май 2015
18 предложений от 17 поставщиков
IC DIG MICROMIRROR DEV 149CPGA. Digital Micromirror Device (DMD) 149-CPGA (22.3x32.2). Specialized ICs
DLP5500BFYA
44 443 ₽
DLP5500BFYA
46 982 ₽
LifeElectronics
DLP5500FYAT
DLP5500AFYA
DLP5500AFYADLP5500BFYA
Статус продуктаНе рекомендуется для новых разработокВ производстве
N12
Pin149149
Package TypeFYAFYA
Industry STD TermCPGACPGA
JEDEC CodeR-CLGA-NR-CLGA-N
Width (мм)32.232.2
Length (мм)22.322.3
Thickness (мм)44
Pitch (мм)1.271.27
Max Height (мм)5.45.4
Package QTY5
CarrierJEDEC TRAY (5+1)
Parameters / ModelsDLP5500AFYA
DLP5500AFYA
DLP5500BFYA
DLP5500BFYA
# Triggers, Input / OutputN/A
Approx. Price (US$)403.20 | 1ku
Chipset FamilyDLP5500DLP5500
Component TypeDMDDMD
Display ResolutionXGA
Illumination Wavelength Range, nm420-700
Illumination Wavelength Range(nm)420-700
Max Display ResolutionXGA
Max Pattern Rate, 8-bit, Hz500
Max Pattern Rate, 8-bit(Hz)500
Max Pattern Rate, Binary, Hz5000
Max Pattern Rate, Binary(Hz)5
000
Max Pixel Data Rate, Gbps3.9
Max Pixel Data Rate(Gbps)3.9
Micromirror Array OrientationOrthogonalOrthogonal
Micromirror Array Size1024x7681024x768
Micromirror Driver SupportExternalExternal
Micromirror Pitch, um10.8
Micromirror Pitch(um)10.8
Package GroupCPGACPGA
Power Consumption, Typical, mW1700
Power Consumption, Typical(mW)1700
Thermal Dissipation, В°C/W0.6
Thermal Dissipation (В°C/W)0.6
RoHSНе совместимСовместим
  • DLPВ® Series-450 DMD and System Mounting Concepts
    PDF, 5.0 Мб, Файл опубликован: 18 июн 2010
    As an aid to the successful first time utilization and implementation of the DLP5500, Series-450 DMD, thisapplication report addresses the following topics:TerminologySpecification and design details of a Series-450 DMDSystem mounting concepts for a Series-450 DMD, including key attributes and important applicationdesign considerationsSockets for use
  • Series 4xx DMD Handling Specification
    PDF, 55 Кб, Файл опубликован: 18 июн 2010
    PURPOSEDefine the minimum requirements for DMD HandlingEstablish precautions to protect the DMD from Electrostatic Discharge (ESD)Establish precautions to protect the DMD’s glass and electrical contacts
  • Series 4xx DMD Cleaning Procedure
    PDF, 41 Кб, Файл опубликован: 18 июн 2010
    Provide correct and consistent methods for cleaning the glass of the DMD in such a way that theanti-reflective coatings on the glass surface are not damaged.
  • DLP Light Commander Kit: Extending the Connection Between the Controller and DMD
    PDF, 387 Кб, Файл опубликован: 1 дек 2011
    The DLP LightCommander development kit was introduced as a platform for exploring the possibilities ofDLP technology, and facilitating the development of customer DLP applications. The LightCommander ismodular in concept, allowing for a certain amount of flexibility in the arrangement of the components andmodifications to the default setup.One of the configurations often requested involv
  • DLP LightCommander API Reference Manual (Rev. C)
    PDF, 247 Кб, Версия: C, Файл опубликован: 13 май 2013
  • DLP LightCommander API Application Report (Rev. C)
    PDF, 928 Кб, Версия: C, Файл опубликован: 5 июн 2013
  • Using DLPВ® Development Kits for 3D Optical Metrology Systems
    PDF, 590 Кб, Файл опубликован: 13 май 2011
    Structured light is the process of projecting known patterns of pixels onto an object. When combined witha synchronized camera, a structured light pattern generator can enable highly accurate 3D opticalmeasurements.This application note presents the operating theory of structured light systems, as well as the keycomponents and design considerations. Special attention is given to hardware
  • Geometric Optics for DLPВ®
    PDF, 714 Кб, Файл опубликован: 5 дек 2013
    DLP3000, DLP4500, DLP5500, DLP7000, DLP9500, DLPВ® LightCrafterв„ў, DLPВ® LightCrafter 4500в„ў Geometric Optics for DLP
  • Wavelength Transmittance Considerations for DLP DMD Windows (Rev. C)
    PDF, 771 Кб, Версия: C, Файл опубликован: 21 мар 2014
    Wavelength Transmittance Considerations for DLP DMD Windows /DLP/Application_Reports/DLPA031/DLPS500
  • DMD 101: Introduction to Digital Micromirror Device (DMD) Technology (Rev. A)
    PDF, 3.9 Мб, Версия: A, Файл опубликован: 7 окт 2013
  • Mounting Hardware and Quick Reference Guide for DLPВ® Advanced Light Control DMDs
    PDF, 383 Кб, Файл опубликован: 20 июл 2016
Серия: DLP5500 (2)
  • Semiconductors> DLP Products> Advanced Light Control> Pattern Rate (<8 kHz)
На английском языке: Datasheet Texas Instruments DLP5500
