Datasheet Texas Instruments DLP6500BFLQ — Даташит
СерияDLP6500FLQ
МодельDLP6500BFLQ
DLP® 0,65 1080p Тип A DMD 203-CLGA
DLP6500 0.65 1080p MVSP Type A DMD datasheet
PDF, 660 Кб, Версия: A, Файл опубликован: 31 окт 2016
IC DIG MICROMIRROR DEV 203CLGA. Digital Micromirror Device (DMD), DLP PMIC 203-CLGA (40.64x31.75). Specialized ICs
DLP6500BFLQ
160 188 ₽
DLP6500BFLQ
Hi-Tech Circuit Group
DLP6500BFLQ
DLP6500BFLQ
Pin203
Package TypeFLQ
Industry STD TermCLGA
JEDEC CodeR-CLGA-N
Package QTY1
Width (мм)31.75
Length (мм)40.64
Thickness (мм)6.01
Pitch (мм)2.54
Max Height (мм)6.6
# TriggersN/A Input / Output
Chipset FamilyDLP6500FLQ
Component TypeDMD
Display Resolution1080p
Illumination Wavelength Range400-700 nm
Max Pattern Rate, 8-bit1446 Hz
Max Pattern Rate, Binary11574 Hz
Max Pixel Data Rate24 Gbps
Micromirror Array OrientationOrthogonal
Micromirror Array Size1920x1080
Micromirror Driver SupportIntegrated
Micromirror Pitch7.6 um
Package GroupCLGA
Power Consumption, Typical6300 mW
Thermal Dissipation0.7 В°C/W
  • Evaluation Modules & Boards: DLPLCR6500EVM
    DLPВ® LightCrafterВ™ 6500 Evaluation Module
  • Mounting Hardware and Quick Reference Guide for DLPВ® Advanced Light Control DMDs
    PDF, 383 Кб, Файл опубликован: 20 июл 2016
Серия: DLP6500FLQ (2)
  • Semiconductors > DLP Products > Advanced Light Control > High Speed Visible
На английском языке: Datasheet Texas Instruments DLP6500BFLQ
