Datasheet Texas Instruments DP83620SQE/NOPB — Даташит
СерияDP83620
МодельDP83620SQE/NOPB
Промышленный однопортовый приемопередатчик Eth Phys Layer 10/100 Мбит/с с поддержкой оптоволокна 48-WQFN от -40 до 85
Industrial Temp Single Port 10/100 Mbps Ethernet PHY Xceiver w/Fiber Support datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 15 апр 2013
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаDP83620SQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Cable Length150 m
Datarate10/100 Mbps
FunctionPHY
InterfaceMII,RMII
JTAG1149.1Yes
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Port CountSingle
Special FeaturesFX Support,Cable Diagnostics
Напряжение питания3.3 Volt
  • Evaluation Modules & Boards: DP83620-EVK
    DP83620 Evaluation Demo Board
  • AN-1469 PHYTERВ® Design & Layout Guide (Rev. D)
    PDF, 289 Кб, Версия: D, Файл опубликован: 26 апр 2013
    This application report describes PHYTERв„ў design and layout guidelines.
  • AN-1794 Using RMII Master Mode (Rev. A)
    PDF, 63 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Texas Instruments PHYTERВ® family of products incorporate the Reduced Media Independent Interface (RMII) as described in the RMII revision 1.2 specification from the RMII Consortium. This interface may be used to connect a PHY device to a MAC in 10/100 Mb/s systems using a reduced number of pins relative to standard MII. In this mode, data is transferred two bits at a time using a 50 MHz refere
  • Improving Electro-Magnetic Noise Immunity in Serial Communications Systems (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note provides key recommendations for implementing serial communication systems that exceed IEC immunity test standards. To provide an example of highly reliable serial communications system implementation and testing, a Texas Instruments DP83640 Ethernet Physical Layer device was tested for International Electrotechnical Commission (IEC) immunity test compliance. Results from the
  • DP83640 Synchronous Ethernet Mode: Achieving Sub-ns Accuracy in PTP Applications (Rev. A)
    PDF, 757 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note first provides a summary of empirical results found when master to slave node synchronization is measured with Synchronous Ethernet mode enabled. Background information is then provided describing the operation of and topological constraints associated with Synchronous Ethernet mode. Typical applications are then described, followed by empirical data which clearly demonstrate
  • Reducing Radiated Emissions in Ethernet 10/100 LAN Applications (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains how Texas Instruments' PHYTER products help system designers toreduce radiated emissions in Ethernet 10/100 LAN applications.
  • AN-1540 Power Measurement of Ethernet Physical Layer Products (Rev. B)
    PDF, 79 Кб, Версия: B, Файл опубликован: 26 апр 2013
    System designers require accurate component power consumption specifications, for the purposes of thermal management, component selection, and power distribution planning.
  • AN-1548 PHYTER 100 Base-TX Reference Clock Jitter Tolerance (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The use of a reference clock that is less stable than those directly driven from an oscillator may be required for some applications. In addition, some customer applications may require partnering with devices that operate outside of the IEEE 802.3 standard for transmitted jitter.
Серия: DP83620 (3)
  • Semiconductors > Interface > Ethernet > Ethernet PHY
На английском языке: Datasheet Texas Instruments DP83620SQE/NOPB
