Datasheet Texas Instruments DP83848LFQSQE — Даташит
СерияDP83848LFQ
МодельDP83848LFQSQE
DP83848LFQ PHYTERв„ў Extended-Temperature, Single-Port 10/100-Mbps Ethernet Physical Layer Transceiver datasheet
PDF, 2.2 Мб, Версия: A, Файл опубликован: 13 апр 2015
Pin40
Package TypeRMM
Package QTY250
CarrierSMALL T&R
Маркировка83848LF
Width (мм)6
Length (мм)6
Thickness (мм).9
Cable Length150 m
Datarate10/100 Mbps
FunctionPHY
InterfaceMII,RMII
JTAG1149.1No
Package GroupVQFN
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
Port CountSingle
RatingAutomotive
Special FeaturesAEC-Q100 Grade 2
Напряжение питания3.3 Volt
  • AN-976 Multiple Function Interface Design Challenges
    PDF, 158 Кб, Файл опубликован: 3 май 2004
  • AN-1519 DP83848 PHYTERВ® Transformerless Ethernet Operation (Rev. A)
    PDF, 249 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report describes a method for using Texas Instruments PHYTERв„ў products withouttransformer magnetics. This includes a list of recommendations for configuring transformerless systems. Adescription of a typical network configuration is provided, followed by descriptions of non-typicaltransformerless configurations. Finally, this application note presents PHYTER product pe
  • AN-1499 DP83846 to DP83848C/I/YB PHYTER System Rollover Document (Rev. B)
    PDF, 178 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This is an informational document detailing points to be considered when updating an existing 10/100Mb/s Ethernet design, using Texas Instruments DP83846 Ethernet Physical Layer (PHY) product, to thenew DP83848C/I/YB PHYTER product. Although the basic functions of the device are similar, differencesinclude feature set, pin functions, package and pinout, and possibly register operation. The i
  • DP83848 - Single 10/100 Mb/s Ethernet Transceiver Energy Detect Mode (Rev. A)
    PDF, 38 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains the concept and the operation of the Energy Detect mode of the DP83848.
  • DP83848 - Single 10/100 Mb/s Ethernet Transceiver Ini During Pwr Dwn Mode (Rev. A)
    PDF, 41 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report details the procedure to put the device into Power Down mode during initialization,configure the registers of the device to the desired mode, and then exit Power Down.
  • DP83848 Sin 10/100Mb/s Ethernet Transcvr Reduced Media Indep Interfce RMII Mode (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report summarizes how a designer can take advantage of RMII mode of the DP83848 toprovide lower cost system design.
  • Improving Electro-Magnetic Noise Immunity in Serial Communications Systems (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note provides key recommendations for implementing serial communication systems that exceed IEC immunity test standards. To provide an example of highly reliable serial communications system implementation and testing, a Texas Instruments DP83640 Ethernet Physical Layer device was tested for International Electrotechnical Commission (IEC) immunity test compliance. Results from the
  • AN-1511 Cable Discharge Event (Rev. A)
    PDF, 262 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses exposing semiconductor devices to potentially destructive Electro StaticDischarge (ESD).
  • Diff Between NSC 10/100 Mb/s Ethernet Physical Layer Devices (Rev. A)
    PDF, 116 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the differences between the 10/100 Mb/s Ethernet Physical Layerdevices, DP8384x.
  • AN-1507 DP83848 and DP83849 100Mb Data Latency (Rev. B)
    PDF, 301 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this document is to define the 100Mb Transmit and Receive latencies of the TexasInstruments Semiconductor DP83848 and DP83849 Ethernet Transceiver family, and to document theircontributions for end-to-end packet transfer in both MII and RMII modes of operation.
  • AN-1540 Power Measurement of Ethernet Physical Layer Products (Rev. B)
    PDF, 79 Кб, Версия: B, Файл опубликован: 26 апр 2013
    System designers require accurate component power consumption specifications, for the purposes of thermal management, component selection, and power distribution planning.
  • Reducing Radiated Emissions in Ethernet 10/100 LAN Applications (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains how Texas Instruments' PHYTER products help system designers toreduce radiated emissions in Ethernet 10/100 LAN applications.
  • AN-1469 PHYTERВ® Design & Layout Guide (Rev. D)
    PDF, 289 Кб, Версия: D, Файл опубликован: 26 апр 2013
    This application report describes PHYTERв„ў design and layout guidelines.
  • AN-1548 PHYTER 100 Base-TX Reference Clock Jitter Tolerance (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The use of a reference clock that is less stable than those directly driven from an oscillator may be required for some applications. In addition, some customer applications may require partnering with devices that operate outside of the IEEE 802.3 standard for transmitted jitter.
Серия: DP83848LFQ (2)
  • Semiconductors > Interface > Ethernet > Ethernet PHY
На английском языке: Datasheet Texas Instruments DP83848LFQSQE
