Datasheet Texas Instruments DP83848YB — Даташит
СерияDP83848YB
МодельDP83848YB
PHYTER Однопортовый приемопередатчик физического уровня Ethernet 10/100 Мбит/с для экстремальных температур 48-HLQFP
DP83848C/I/VYB/YB PHYTERв„ў QFP Single Port 10/100 Mb/s Ethernet Physical Layer Transceiver datasheet
PDF, 3.0 Мб, Версия: E, Файл опубликован: 6 мар 2015
Pin48
Package TypePTB
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Approx. Price (US$)16.60 | 1ku
Cable Length(m)150
Datarate(Mbps)10/100
FunctionPHY
InterfaceMII
RMII
SNI
JTAG1149.1Yes
Operating Temperature Range(C)-40 to 125
Package GroupHLQFP
Package Size: mm2:W x L (PKG)48HLQFP: 81 mm2: 9 x 9(HLQFP)
Port CountSingle
Supply Voltage(Volt)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: DP83848I-POE-EK
    PHYTERВ® Industrial Temperature Single Port 10 100 Mbs Ethernet Physical Layer Transceiver
  • Evaluation Modules & Boards: DP83848I-MAU-EK
  • AN-1499 DP83846 to DP83848C/I/YB PHYTER System Rollover Document (Rev. B)
    PDF, 178 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This is an informational document detailing points to be considered when updating an existing 10/100Mb/s Ethernet design, using Texas Instruments DP83846 Ethernet Physical Layer (PHY) product, to thenew DP83848C/I/YB PHYTER product. Although the basic functions of the device are similar, differencesinclude feature set, pin functions, package and pinout, and possibly register operation. The i
  • AN-1519 DP83848 PHYTERВ® Transformerless Ethernet Operation (Rev. A)
    PDF, 249 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report describes a method for using Texas Instruments PHYTERв„ў products withouttransformer magnetics. This includes a list of recommendations for configuring transformerless systems. Adescription of a typical network configuration is provided, followed by descriptions of non-typicaltransformerless configurations. Finally, this application note presents PHYTER product pe
  • DP83848 Sin 10/100Mb/s Ethernet Transcvr Reduced Media Indep Interfce RMII Mode (Rev. A)
    PDF, 168 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report summarizes how a designer can take advantage of RMII mode of the DP83848 toprovide lower cost system design.
  • DP83848 - Single 10/100 Mb/s Ethernet Transceiver Ini During Pwr Dwn Mode (Rev. A)
    PDF, 41 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report details the procedure to put the device into Power Down mode during initialization,configure the registers of the device to the desired mode, and then exit Power Down.
  • DP83848 - Single 10/100 Mb/s Ethernet Transceiver Energy Detect Mode (Rev. A)
    PDF, 38 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains the concept and the operation of the Energy Detect mode of the DP83848.
  • DP83848 PHYTERВ® 10/100 Single Port Physical Layer Products
    PDF, 740 Кб, Файл опубликован: 15 май 2012
  • DP83848I PHYTER Single to DP83848K/T PHYTER Mini System Rollover Document (Rev. B)
    PDF, 145 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This document discusses points to be considered when migrating an existing 10/100 Mb/s Ethernet designusing the Texas Instruments DP83848I PHYTER product to the smaller DP83848K or DP83848Tproducts.
  • App Nte 1565 LXT972M to DP83848C/I/YB PHYTER Sys Rollovr Doc (Rev. A)
    PDF, 160 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report provides information about the process to upgrade an existing 10/100 Mb/sEthernet design, using Intel’s LXT972M Ethernet Physical Layer (PHY) product, our new DP83848C/I/YBPHYTER product.
  • LXT971/972A to DP83848C/I/YB PHYTER System Rollover Document (Rev. B)
    PDF, 164 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report provides points to be considered when upgrading an existing 10/100 Mb/s Ethernetdesign, using Intel’s LXT971 or LXT972A Ethernet Physical Layer (PHY) product, to the new TexasInstruments DP83848C/I/YB PHYTER™ product.
  • AN-1511 Cable Discharge Event (Rev. A)
    PDF, 262 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses exposing semiconductor devices to potentially destructive Electro StaticDischarge (ESD).
  • Diff Between NSC 10/100 Mb/s Ethernet Physical Layer Devices (Rev. A)
    PDF, 116 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the differences between the 10/100 Mb/s Ethernet Physical Layerdevices, DP8384x.
  • AN-1507 DP83848 and DP83849 100Mb Data Latency (Rev. B)
    PDF, 301 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this document is to define the 100Mb Transmit and Receive latencies of the TexasInstruments Semiconductor DP83848 and DP83849 Ethernet Transceiver family, and to document theircontributions for end-to-end packet transfer in both MII and RMII modes of operation.
  • AN-1469 PHYTERВ® Design & Layout Guide (Rev. D)
    PDF, 289 Кб, Версия: D, Файл опубликован: 26 апр 2013
    This application report describes PHYTERв„ў design and layout guidelines.
  • Reducing Radiated Emissions in Ethernet 10/100 LAN Applications (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains how Texas Instruments' PHYTER products help system designers toreduce radiated emissions in Ethernet 10/100 LAN applications.
  • AN-1540 Power Measurement of Ethernet Physical Layer Products (Rev. B)
    PDF, 79 Кб, Версия: B, Файл опубликован: 26 апр 2013
    System designers require accurate component power consumption specifications, for the purposes of thermal management, component selection, and power distribution planning.
  • AN-1548 PHYTER 100 Base-TX Reference Clock Jitter Tolerance (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The use of a reference clock that is less stable than those directly driven from an oscillator may be required for some applications. In addition, some customer applications may require partnering with devices that operate outside of the IEEE 802.3 standard for transmitted jitter.
Серия: DP83848YB (3)
  • Semiconductors > Interface > Ethernet
На английском языке: Datasheet Texas Instruments DP83848YB
