Datasheet Texas Instruments DP83849IDVSX/NOPB — Даташит
СерияDP83849ID
МодельDP83849IDVSX/NOPB
PHYTER DUAL Industrial Temp с поддержкой оптоволокна (FX), двухпортовый Eth Phys Layer Transc 10/100 Мбит/с 80-TQFP от -40 до 85
PHYTER DUAL Ind Temp w/Fiber Support Dual Port 10/100 Mb/s Ethernet PHY X-ceiver datasheet
PDF, 866 Кб, Версия: E, Файл опубликован: 27 май 2008
Pin80
Package TypePFC
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаDP83849IDVS
Width (мм)12
Length (мм)12
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Cable Length137 m
Datarate10/100 Mbps
FunctionPHY
InterfaceMII,RMII,SNI
JTAG1149.1Yes
Package GroupTQFP
Package Size: mm2:W x L80TQFP: 196 mm2: 14 x 14(TQFP) PKG
Port CountDual
Special FeaturesFX Support,Cable Diagnostics
Напряжение питания3.3 Volt
  • Evaluation Modules & Boards: DP83849IFVS-EVK
    DP83849IFVS Basic product evaluation and customer demo board with FX
  • AN-1469 PHYTERВ® Design & Layout Guide (Rev. D)
    PDF, 289 Кб, Версия: D, Файл опубликован: 26 апр 2013
    This application report describes PHYTERв„ў design and layout guidelines.
  • AN-1508 DP83849 Cable Diagnostics (Rev. A)
    PDF, 454 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report describes the features incorporated in the DP83849 for detecting cabling faults andmonitoring link status in a Twisted Pair cabling environment.
  • Reducing Radiated Emissions in Ethernet 10/100 LAN Applications (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application report explains how Texas Instruments' PHYTER products help system designers toreduce radiated emissions in Ethernet 10/100 LAN applications.
  • AN-1509 PhyterDual Flexible Port Switching (Rev. B)
    PDF, 118 Кб, Версия: B, Файл опубликован: 26 апр 2013
    Texas Instruments flexible port switching offers an unprecedented number of ways for system designers todevelop solutions that address specific application needs with the minimum number of components. Thecombination of flexible assignment of data paths between ports and the ability to change theseassignments dynamically allow one part to meet many different needs. In addition to this flexibi
  • AN-1540 Power Measurement of Ethernet Physical Layer Products (Rev. B)
    PDF, 79 Кб, Версия: B, Файл опубликован: 26 апр 2013
    System designers require accurate component power consumption specifications, for the purposes of thermal management, component selection, and power distribution planning.
  • AN-1507 DP83848 and DP83849 100Mb Data Latency (Rev. B)
    PDF, 301 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this document is to define the 100Mb Transmit and Receive latencies of the TexasInstruments Semiconductor DP83848 and DP83849 Ethernet Transceiver family, and to document theircontributions for end-to-end packet transfer in both MII and RMII modes of operation.
  • AN-1548 PHYTER 100 Base-TX Reference Clock Jitter Tolerance (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The use of a reference clock that is less stable than those directly driven from an oscillator may be required for some applications. In addition, some customer applications may require partnering with devices that operate outside of the IEEE 802.3 standard for transmitted jitter.
Серия: DP83849ID (2)
  • Semiconductors > Interface > Ethernet > Ethernet PHY
На английском языке: Datasheet Texas Instruments DP83849IDVSX/NOPB
