Datasheet Texas Instruments DP83867E — Даташит
СерияDP83867E
PHY Gigabit Ethernet с расширенной температурой и SGMII
DP83867E/IS/CS Robust, High Immunity, Small Form Factor 10/100/1000 Ethernet Physical Layer Transceiver datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 7 мар 2017
DP83867ERGZRDP83867ERGZT
Доступность образцов у производителяДаДа
N12
Pin4848
Package TypeRGZRGZ
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY2500250
CarrierLARGE T&RLARGE T&R
МаркировкаDP83867EDP83867E
Width (мм)77
Length (мм)77
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsDP83867ERGZR
DP83867ERGZR
DP83867ERGZT
DP83867ERGZT
Cable Length, m130130
Datarate, Mbps10/100/100010/100/1000
FunctionPHYPHY
InterfaceRGMII,SGMIIRGMII,SGMII
JTAG1149.1YesYes
Рабочий диапазон температур, Cот -40 до 105от -40 до 105
Package GroupVQFNVQFN
Package Size: mm2:W x L, PKG48VQFN: 49 mm2: 7 x 7(VQFN)48VQFN: 49 mm2: 7 x 7(VQFN)
Port CountSingleSingle
RatingCatalogCatalog
Special FeaturesCable Diagnostics,IEEE 1588 SOFCable Diagnostics,IEEE 1588 SOF
Напряжение питания, Volt1,2.51,2.5
RoHSСовместимСовместим
  • Importance of Latency in Factory Automation
    PDF, 196 Кб, Файл опубликован: 25 окт 2015
    Latency is a critical parameter in Ethernet networks developed for Factory Automation applications. Latency is not a defined value for Ethernet as specified by the IEEE 802.3 standard. Nor is Ethernet inherently synchronous or repeatable. This disconnect between the inherent characteristics of Ethernet and the needs of Factory Automation applications must be bridged though care
  • Configuring Ethernet Devices with 4-Level Straps
    PDF, 212 Кб, Файл опубликован: 17 май 2016
  • RGMII Interface Timing Budgets
    PDF, 185 Кб, Файл опубликован: 28 окт 2015
    RGMII Interface Timing Budgets is intended to serve as a guideline for developing a timing budget when using the RGMII v1.3 and v2.0 standard with a Gigabit PHY transceiver like the DP83867.
  • DP83867 Troubleshooting Guide (Rev. A)
    PDF, 700 Кб, Версия: A, Файл опубликован: 6 апр 2016
    A 10/100/1000 Ethernet Physical Layer device has multiple connections and many possible configurationoptions. While the DP83867 is designed with a priority on ease of use, there are many factors to considerduring initial board bring up. This application note provides guidance on the key criteria to verify in order toexpedite initial validation of DP83867 applications.
  • DP83867E/IS/CS/IR/CR RGZ Power Consumption Data
    PDF, 92 Кб, Файл опубликован: 7 окт 2015
    Power consumption on an Ethernet PHY is affected by different operating conditions. System design around Ethernet products requires accurate power consumption numbers for component selection, thermal management and power distribution planning. This application report details power consumption of DP83867 in different conditions.
  • How to Configure DP83867 Start of Frame
    PDF, 78 Кб, Файл опубликован: 27 окт 2015
    The DP83867 can detect a Start of Frame Delimiter (SFD) for transmit and receive packets and output a pulse via a GPIO that can be used to assess the latency of the link between the DP83867 and a timestamp capable partner. For real-time systems and systems implementing the IEEE 1588 Precision Time Protocol (PTP) to timestamp packets for synchronizing devices across the network,
  • How to Configure DP838XX for Ethernet Compliance and Loopback Testing (Rev. A)
    PDF, 820 Кб, Версия: A, Файл опубликован: 31 янв 2017
    This application report covers how to setup and configure the DP838xx PHY (using the customer EVM) forEthernet Physical Layer Compliance (IEEE 802.3) testing as the device under test (DUT). This applicationnote primarily uses DP83867 as an example, but any DP838xx can use these procedures for compliancetesting.Refer to DP83822 IEEE 802.3u Compliance and Debug (SNLA266) for a DP83822 specif
Серия: DP83867E (2)
  • Semiconductors> Interface> Ethernet
На английском языке: Datasheet Texas Instruments DP83867E
