Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DRV3220QPHPRQ1 — Даташит
СерияDRV3220-Q1
МодельDRV3220QPHPRQ1
Трехфазный драйвер автомобильных ворот 48-HTQFP от -40 до 125
DRV3220-Q1 Three-Phase Automotive Gate Driver With Enhanced Protection, Diagnostics, and Monitoring datasheet
PDF, 1.1 Мб, Файл опубликован: 17 фев 2017
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаDRV3220Q1
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Additional FeaturesAutomotive Qualified,VDS Monitoring,VGS Monitoring,Q&A Watchdog,Internal Driver Diagnostics,System Supervision Functions,Shoot-Through Protection,Over Voltage Protection,Under Voltage Protection,Over Temperature Protection,Sleep Mode
Control I/F6x direct predriver control inputs, SPI
Gate Drive1 A
Number of Half Bridges3
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
RatingAutomotive
Vs ABS(Max)60 В
Vs ABS(Min)-0.3 В
Vs(Min)4.75 В
  • Evaluation Modules & Boards: DRV3205EVM
    DRV3205-Q1 Three-Phase Automotive Gate Driver Evaluation Module
  • Protecting Automotive Motor Drive Systems from Reverse Polarity Conditions
    PDF, 99 Кб, Файл опубликован: 25 окт 2016
    Electronics are integrated into virtually every system of the modern automobile, from safety to infotainment. Now more than ever it is important for manufacturers to build robust protection into the electrical systems of their vehicles.One danger that all electrical systems face is a reversed polarity from the power source. This event can be caused by a short circuit, but is usually c
Серия: DRV3220-Q1 (1)
  • DRV3220QPHPRQ1
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Gate Drivers for Safety Applications
На английском языке: Datasheet Texas Instruments DRV3220QPHPRQ1
