Datasheet Texas Instruments DRV3220-Q1 — Даташит
| Серия | DRV3220-Q1 |
Трехфазный драйвер автомобильных ворот
DRV3220-Q1 Three-Phase Automotive Gate Driver With Enhanced Protection, Diagnostics, and Monitoring datasheet
PDF, 1.1 Мб, Файл опубликован: 17 фев 2017
Купить DRV3220 на РадиоЛоцман.Цены — от 140 до 2 853 ₽11 предложений от 11 поставщиков IC MOTOR DRIVER 48HTQFP. Bipolar Motor Driver Power MOSFET PWM 48-HTQFP (7x7). PMIC - Motor Drivers, Controllers | |||
| DRV3220QPHPRQ1 Texas Instruments | 140 ₽ | ||
| DRV3220QPHPRQ1 Texas Instruments | 354 ₽ | ||
| DRV3220QPHPRQ1 Texas Instruments | 427 ₽ | ||
| DRV3220QPHPRQ1 Texas Instruments | 752 ₽ | ||
| DRV3220QPHPRQ1 | |
| DRV3220QPHPRQ1 | |
| N | 1 |
| Pin | 48 |
| Package Type | PHP |
| Industry STD Term | HTQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | DRV3220Q1 |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Parameters / Models | DRV3220QPHPRQ1![]() |
| Additional Features | Automotive Qualified,VDS Monitoring,VGS Monitoring,Q&A Watchdog,Internal Driver Diagnostics,System Supervision Functions,Shoot-Through Protection,Over Voltage Protection,Under Voltage Protection,Over Temperature Protection,Sleep Mode |
| Control I/F | 6x direct predriver control inputs, SPI |
| Gate Drive, A | 1 |
| Number of Half Bridges | 3 |
| Рабочий диапазон температур, C | от -40 до 125 |
| Package Group | HTQFP |
| Package Size: mm2:W x L, PKG | 48HTQFP: 81 mm2: 9 x 9(HTQFP) |
| Rating | Automotive |
| Vs ABS(Max), В | 60 |
| Vs ABS(Min), В | -0.3 |
| Vs(Min), В | 4.75 |
| DRV3220QPHPRQ1 | |
- Protecting Automotive Motor Drive Systems from Reverse Polarity ConditionsPDF, 99 Кб, Файл опубликован: 25 окт 2016
Electronics are integrated into virtually every system of the modern automobile, from safety to infotainment. Now more than ever it is important for manufacturers to build robust protection into the electrical systems of their vehicles.One danger that all electrical systems face is a reversed polarity from the power source. This event can be caused by a short circuit, but is usually c
Серия: DRV3220-Q1 (1)
- Semiconductors> Motor Drivers> Brushless DC (BLDC) Drivers> Brushless DC Gate Drivers for Safety Applications
