Datasheet Texas Instruments DRV592VFPG4 — Даташит
СерияDRV592
МодельDRV592VFPG4
Высокоэффективный H-мост (требуется внешний ШИМ) 32-HLQFP от -40 до 85
+/-3-A High-Efficiency H-Bridge (Requires External PWM) datasheet
PDF, 379 Кб, Версия: A, Файл опубликован: 9 май 2002
Pin32
Package TypeVFP
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).8
Max Height (мм)1.6
RoHSНе совместим
  • Thermo-Electric Cooler Control Using a TMS320F2812 DSP & DRV592 Power Amplifier
    PDF, 378 Кб, Файл опубликован: 7 фев 2003
    This application report presents a thermoelectric cooler system consisting of a Texas Instruments TMS320F2812 digital signal processor (DSP) and DRV592 power amplifier. The DSP implements a digital proportional-integral-derivative feedback controller using an integrated 12-bit analog-to-digital converter to read the thermistor, and direct output of pulse-width-modulated waveforms to the H-bridge D
  • PWM Power Driver Modulation Schemes
    PDF, 56 Кб, Файл опубликован: 29 окт 2001
    This application report describes the modulation schemes implemented in the DRV59x family of PWM power drivers to facilitate user design efforts. Texas Instruments offers three modulation options with the introduction of the DRV590 and DRV591 PWM power drivers and the DRV592 H-bridge.
Серия: DRV592 (2)
  • Semiconductors > Amplifiers > Special Function Amplifiers > TEC/Laser PWM Power Amplifiers
На английском языке: Datasheet Texas Instruments DRV592VFPG4
