Datasheet Texas Instruments DRV603 — Даташит
СерияDRV603
3-Vrms DirectPathв„ў Pop-Free Variable Input Gain Line Driver with Diff Inputs
DIRECTPATH (tm), Pop-Free 3-Vrms Line Driver With Adjustable Gain datasheet
PDF, 817 Кб, Версия: C, Файл опубликован: 18 ноя 2009
DRV603PWDRV603PWR
Доступность образцов у производителяНетДа
DRV603PWDRV603PWR
N12
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY902000
CarrierTUBELARGE T&R
МаркировкаDRV603DRV603
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Parameters / ModelsDRV603PW
DRV603PW
DRV603PWR
DRV603PWR
Analog Supply (V), Min35.5
Gain, V/VAdjustableAdjustable
Input Offset (+/-), uV10001000
Iq(Typ), мА1111
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
PSRR, дБ8888
Package GroupTSSOPTSSOP
Package Size: mm2:W x L, PKG14TSSOP: 32 mm2: 6.4 x 5(TSSOP)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Pin/Package14TSSOP14TSSOP
DRV603PWDRV603PWR
RoHSСовместимСовместим
  • DAC Post-Filter Design Based on DRV6xx Family (Rev. A)
    PDF, 166 Кб, Версия: A, Файл опубликован: 23 ноя 2010
    This application report describes DAC post-filter design based on the Texas Instruments DirectPathв„ў line driver products. Theories, detailed design steps, and application circuits are discussed for Blu-rayв„ў DVD players, as an example. These theories, detail design steps, and application circuits are applicable to any other applications with the use of DACs.
Серия: DRV603 (2)
  • Semiconductors> Audio> Low-Power Audio Amplifiers ( 2V/3Vrms Line Driver
На английском языке: Datasheet Texas Instruments DRV603
