Datasheet Texas Instruments DRV8303 — Даташит
СерияDRV8303
Трехфазный предварительный драйвер с двухточечными шунтирующими усилителями
DRV8303 Three-Phase Gate Driver With Dual-Current Shunt Amplifiers datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 8 дек 2016
DRV8303DCADRV8303DCAR
Доступность образцов у производителяДаНет
N12
Pin4848
Package TypeDCADCA
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY402000
CarrierTUBELARGE T&R
МаркировкаDRV8303DRV8303
Width (мм)6.16.1
Length (мм)12.512.5
Thickness (мм)1.151.15
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsDRV8303DCA
DRV8303DCA
DRV8303DCAR
DRV8303DCAR
Additional FeaturesSPI Management I/FSPI Management I/F
Control I/FPWM (6x/3x)PWM (6x/3x)
Current Sense Amps22
Gate Drive, A1.71.7
Number of Half Bridges33
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Package GroupHTSSOPHTSSOP
Package Size: mm2:W x L, PKG48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP)48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP)
RatingCatalogCatalog
Vs(Max), В6060
Vs(Min), В66
RoHSСовместимСовместим
  • Hardware Design Considerations for an Electric Bicycle using BLDC Motor
    PDF, 530 Кб, Файл опубликован: 11 июн 2014
    A traditional bicycle is a two-wheel vehicle that is propelled by the rider who delivers muscle power through pedals that rotate one of the two wheels. The rider steers the front wheel to create a force that returns and maintains the vehicle center of gravity into a stable zone whenever necessary, thus keeping the bicycle upright. An electric bicycle carries batteries that deliver electric power t
  • Hardware Design Considerations for an Efficient Vacuum Cleaner using BLDC Motor (Rev. A)
    PDF, 213 Кб, Версия: A, Файл опубликован: 15 июл 2015
    A vacuum cleaner is a device that uses an air pump to create a partial vacuum to suck up dirt and dust particles from a given surface. Vacuum cleaners are used in homes as well as in industries and come with a variety of power levels, small battery-operated hand-held devices, domestic central vacuum cleaners and huge stationary industrial appliances. A universal motor is typically used as suction
  • Sensored 3-Phase BLDC Motor Control Using MSP430
    PDF, 199 Кб, Файл опубликован: 20 июл 2011
    Brushless DC (BLDC) motors are electronically commutated motors that offer many advantages over brushed DC motors and, therefore, are becoming very popular industrially and commercially. This application report discusses a sensored 3-phase BLDC motor control solution using MSP430в„ў as the motor controller. Hall sensors are used to detect the rotor position and close the commutation loop. Both open
Серия: DRV8303 (2)
  • Semiconductors> Motor Drivers> Brushless DC (BLDC) Drivers> Brushless DC Gate Drivers
На английском языке: Datasheet Texas Instruments DRV8303
