Datasheet Texas Instruments DRV8886PWPR — Даташит
СерияDRV8886
МодельDRV8886PWPR
Драйвер шагового двигателя 2 А со встроенным датчиком тока 24-HTSSOP от -40 до 125
DRV8886 2-A Stepper Motor Driver With Integrated Current Sense datasheet
PDF, 1.8 Мб, Файл опубликован: 13 янв 2017
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаDRV8886
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesIntegrated Current Sensing
Control I/FSTEP/DIR
Micro-Stepping Levels16
Number of Full Bridges2
Package Size: mm2:W x L24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) PKG
Peak Output Current2 A
RDS(ON) (HS + LS)600 mOhms
RMS Output Current1.4 A
Vs(Max)37 В
Vs(Min)8 В
  • Evaluation Modules & Boards: DRV8886EVM
    2.0A Stepper Motor Driver With Integrated Sense Resistor Evaluation Module
  • Full-Scale Current Adjustment Using a Digital-to-Analog Converter (DAC)
    PDF, 1.6 Мб, Файл опубликован: 10 мар 2017
    The ability to dynamically control current in an inductive load system is very important for stepper motor designs where different levels of torque control are desired. This adjustment feature can also be used to improve system efficiency by reducing the motor current in low-load situations, achieving a longer battery life.This application report is provided as a supplement t
Серия: DRV8886 (2)
  • Semiconductors > Motor Drivers > Stepper Drivers > Stepper Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV8886PWPR
