Datasheet Texas Instruments DRV8886PWP — Даташит
Серия | DRV8886 |
Модель | DRV8886PWP |
Драйвер шагового двигателя 2 А со встроенным датчиком тока 24-HTSSOP от -40 до 125
DRV8886 2-A Stepper Motor Driver With Integrated Current Sense datasheet
PDF, 1.8 Мб, Файл опубликован: 13 янв 2017
![]() 30 предложений от 14 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Контроллеры двигателей и вентиляторов | |||
DRV8886PWP Texas Instruments | от 70 ₽ | ||
DRV8886PWP Texas Instruments | 143 ₽ | ||
DRV8886PWP Texas Instruments | 480 ₽ | ||
DRV8886PWP Texas Instruments | по запросу |
Pin | 24 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 60 |
Carrier | TUBE |
Маркировка | DRV8886 |
Width (мм) | 4.4 |
Length (мм) | 7.8 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Integrated Current Sensing |
Control I/F | STEP/DIR |
Micro-Stepping Levels | 16 |
Number of Full Bridges | 2 |
Package Size: mm2:W x L | 24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) PKG |
Peak Output Current | 2 A |
RDS(ON) (HS + LS) | 600 mOhms |
RMS Output Current | 1.4 A |
Rating | Catalog |
Vs(Max) | 37 В |
Vs(Min) | 8 В |
- Evaluation Modules & Boards: DRV8886EVM
2.0A Stepper Motor Driver With Integrated Sense Resistor Evaluation Module
- Full-Scale Current Adjustment Using a Digital-to-Analog Converter (DAC)PDF, 1.6 Мб, Файл опубликован: 10 мар 2017
The ability to dynamically control current in an inductive load system is very important for stepper motor designs where different levels of torque control are desired. This adjustment feature can also be used to improve system efficiency by reducing the motor current in low-load situations, achieving a longer battery life.This application report is provided as a supplement t
Серия: DRV8886 (2)
- DRV8886PWP DRV8886PWPR
- Semiconductors > Motor Drivers > Stepper Drivers > Stepper Drivers with FETs
