Datasheet Texas Instruments DS125BR111RTWT — Даташит
СерияDS125BR111
МодельDS125BR111RTWT
2-канальные повторители со сверхнизким энергопотреблением, 12,5 Гбит/с, с входной коррекцией 24-WQFN от -40 до 85
DS125BR111 Low Power 12.5 Gbps 1-Lane Linear Repeater with Equalization datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 22 авг 2014
Pin24
Package TypeRTW
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка2B111A0
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
ApplicationFront Port, Backplane, Peripheral I/O
Device TypeRepeater
Input CompatibilityAC-Coupled,CML
Количество каналов2
Package GroupWQFN
Protocols10G-SR/LR,SAS1,SAS2,SAS3,SATA1,SATA2,SATA3,Infiniband,FibreChannel,CPRI,OBSAI,Interlaken,sRIO,General Purpose
Speed(Max)12.5 Gbps
SupplyVoltage3.3,2.5 Volt
  • Evaluation Modules & Boards: DS125BR111EVM
    DS125BR111EVM 12 Gbps 2-Channel Repeater with Equalization Evaluation Module
  • Advanced Linear Repeater Used in PCIe 3.0 Add-in Card Compliance Environment
    PDF, 689 Кб, Файл опубликован: 2 окт 2014
    This report summarizes the results of PCIe Gen 3.0 add-in card compliance testing using TI’s low-power 12.5 Gbps 8-channel advanced linear repeater. The advanced linear repeater is placed in a mid-channel configuration between a PCIe Gen 3.0 graphics card and a compliance base board (CBB) and tested for jitter, eye mask, and TX preset compliance. The results demonstrate the excellent signal condit
  • Advanced linear equalization in multi-gigabit systems
    PDF, 870 Кб, Файл опубликован: 28 апр 2015
  • Linear Repeaters Used in SAS/SATA Applications
    PDF, 2.4 Мб, Файл опубликован: 21 сен 2015
    This report summarizes the results of SAS/SATA testing using TI’s DS125BR820 and DS125BR401A Low-Power 12.5 Gbps 8-Channel Repeaters. The TI devices are tested in an external miniSAS-HD environment and directly using a DS125BR820EVM. The test results will demonstrate how linear equalization can improve system margin and allow for the extended channel configurations that are required in the latest
  • Channel Tuning Made Easy Using Linear Repeaters for 10G and 12G Applications
    PDF, 3.4 Мб, Файл опубликован: 20 янв 2015
    This report demonstrates the benefits of using Texas Instruments Linear Redrivers to simplify the process of channel tuning and improve system margins. Test results of the DS125BR820 linear redriver operating in various pre-channel and post-channel conditions are presented and show improvements in channel conditions in terms of transmitter pre- and post-cursor error-free operat
  • Analog Applications Journal 2Q 2015
    PDF, 2.5 Мб, Файл опубликован: 28 апр 2015
  • Understanding EEPROM Programming for High Speed Repeaters and Mux Buffers
    PDF, 317 Кб, Файл опубликован: 9 окт 2014
    System designers often use EEPROM (Electrically Erasable Programmable Read-Only Memory) to program a set of customized high speed repeater and mux buffer start-up settings that are different from the default. Using the information here will make repeater EEPROM configuration and programming easy to implement and understand. This application note addresses SMBus-to-EEPROM mapping for 2-channel repe
Серия: DS125BR111 (2)
  • Semiconductors > Interface > Ethernet > Ethernet Retimers, Redrivers/Repeaters and MUX Buffers
На английском языке: Datasheet Texas Instruments DS125BR111RTWT
