Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DS125BR401ANJYR — Даташит
СерияDS125BR401A
МодельDS125BR401ANJYR
Маломощный 4-полосный повторитель 12 Гбит/с с выравниванием 54-WQFN от -40 до 85
DS125BR401A Low-Power 12 Gbps 4-Lane Linear Repeater With Equalization datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 31 мар 2014
Pin54
Package TypeNJY
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY2000
МаркировкаDS125BR401A
Width (мм)5.5
Length (мм)10
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Device TypeRepeater
Input CompatibilityAC Coupled,CML
Количество каналов8
Package GroupWQFN
ProtocolsSAS1,SAS2,SAS3,SATA1,SATA2,SATA3,PCIe1,PCIe2,PCIe3,General Purpose
Speed(Max)12.5 Gbps
SupplyVoltage3.3,2.5 Volt
  • Evaluation Modules & Boards: DS125BR401AEVM
    DS125BR401AEVM: 12-Gbps 4-Lane Repeater With Equalization Evaluation Module
  • Linear Repeaters Used in SAS/SATA Applications
    PDF, 2.4 Мб, Файл опубликован: 21 сен 2015
    This report summarizes the results of SAS/SATA testing using TI’s DS125BR820 and DS125BR401A Low-Power 12.5 Gbps 8-Channel Repeaters. The TI devices are tested in an external miniSAS-HD environment and directly using a DS125BR820EVM. The test results will demonstrate how linear equalization can improve system margin and allow for the extended channel configurations that are required in the latest
  • Channel Tuning Made Easy Using Linear Repeaters for 10G and 12G Applications
    PDF, 3.4 Мб, Файл опубликован: 20 янв 2015
    This report demonstrates the benefits of using Texas Instruments Linear Redrivers to simplify the process of channel tuning and improve system margins. Test results of the DS125BR820 linear redriver operating in various pre-channel and post-channel conditions are presented and show improvements in channel conditions in terms of transmitter pre- and post-cursor error-free operat
  • Understanding EEPROM Programming for High Speed Repeaters and Mux Buffers
    PDF, 317 Кб, Файл опубликован: 9 окт 2014
    System designers often use EEPROM (Electrically Erasable Programmable Read-Only Memory) to program a set of customized high speed repeater and mux buffer start-up settings that are different from the default. Using the information here will make repeater EEPROM configuration and programming easy to implement and understand. This application note addresses SMBus-to-EEPROM mapping for 2-channel repe
Серия: DS125BR401A (2)
  • Semiconductors > Interface > Ethernet > Ethernet Retimers, Redrivers/Repeaters and MUX Buffers
На английском языке: Datasheet Texas Instruments DS125BR401ANJYR
