Datasheet Texas Instruments DS125BR800SQ/NOPB — Даташит
СерияDS125BR800
МодельDS125BR800SQ/NOPB
2,5/5,0/8,0 Гбит/с, 8 каналов PCI Exprs Reptr с Eqlztion и De-Emp 54-WQFN
DS125BR800 Low-Power 12.5-Gbps 8-Channel Repeater With Input Equalization and Output De-Emphasis datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 15 янв 2014
Pin54
Package TypeNJY
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY2000
МаркировкаDS125BR800SQ
Width (мм)5.5
Length (мм)10
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Device TypeRepeater
Input CompatibilityAC-Coupled,CML
Количество каналов8
Package GroupWQFN
Protocols10G-KR,sRIO,Infiniband,Interlaken,CPRI,OBSAI,PCIe1,PCIe2,PCIe3,General Purpose
Speed(Max)12.5 Gbps
SupplyVoltage3.3,2.5 Volt
  • Understanding EEPROM Programming for High Speed Repeaters and Mux Buffers
    PDF, 317 Кб, Файл опубликован: 9 окт 2014
    System designers often use EEPROM (Electrically Erasable Programmable Read-Only Memory) to program a set of customized high speed repeater and mux buffer start-up settings that are different from the default. Using the information here will make repeater EEPROM configuration and programming easy to implement and understand. This application note addresses SMBus-to-EEPROM mapping for 2-channel repe
Серия: DS125BR800 (2)
  • Semiconductors > Interface > Ethernet > Ethernet Retimers, Redrivers/Repeaters and MUX Buffers
На английском языке: Datasheet Texas Instruments DS125BR800SQ/NOPB
