Datasheet Texas Instruments DS25BR110 — Даташит
СерияDS25BR110
Буфер LVDS 3,125 Гбит/с с выравниванием приема
DS25BR110 3.125 Gbps LVDS Buffer with Receive Equalization datasheet
PDF, 879 Кб, Версия: E, Файл опубликован: 14 апр 2013
DS25BR110TSD/NOPBDS25BR110TSDX/NOPB
Доступность образцов у производителяНетДа
N12
Pin88
Package TypeNGQNGQ
Industry STD TermWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY10004500
CarrierSMALL T&RLARGE T&R
Маркировка2R1102R110
Width (мм)33
Length (мм)33
Thickness (мм).8.8
Pitch (мм).5.5
Max Height (мм).8.8
Parameters / ModelsDS25BR110TSD/NOPB
DS25BR110TSD/NOPB
DS25BR110TSDX/NOPB
DS25BR110TSDX/NOPB
Device TypeBufferBuffer
ESD HBM, kV77
FunctionEqualizerEqualizer
ICC(Max), мА4343
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupWSONWSON
Package Size: mm2:W x L, PKGSee datasheet (WSON)See datasheet (WSON)
ProtocolsLVDSLVDS
RoHSСовместимСовместим
  • Extending the Signal Path Over Data Trans Lines Using LVDS Signal Conditioning
    PDF, 575 Кб, Файл опубликован: 2 авг 2007
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • AN-1957 LVDS Signal Conditioners Reduce Data-Dependent Jitter (Rev. A)
    PDF, 275 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Jitter is a phenomenon troubling many designers of high-speed interfaces. It reduces available timingmargin, limits transmission distance between a transmitter and a receiver, and increases system cost bydemanding better performing and more expensive interconnects. LVDS interfaces are not spared fromthese ill effects as they now operate at bit rates exceeding the 3 Gbps mark. Texas Instrumen
Серия: DS25BR110 (2)
  • Semiconductors> Interface> Signal Conditioners> Equalizer
На английском языке: Datasheet Texas Instruments DS25BR110
