Datasheet Texas Instruments DS25BR120TSD/NOPB — Даташит
СерияDS25BR120
МодельDS25BR120TSD/NOPB
Буфер LVDS 3,125 Гбит/с с предыскажением передачи 8-WSON от -40 до 85
DS25BR120 3.125 Gbps LVDS Buffer with Transmit Pre-Emphasis datasheet
PDF, 841 Кб, Версия: E, Файл опубликован: 14 апр 2013
Package TypeNGQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
Маркировка2R120
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Device TypeBuffer
ESD HBM7 kV
FunctionBuffer
ICC(Max)43 мА
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
ProtocolsLVDS
  • Evaluation Modules & Boards: DS25BR100EVK
    3.125 Gbps LVDS Single Channel Buffers with Transmit Pre-emphasis and Receive Equalization family
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • AN-1957 LVDS Signal Conditioners Reduce Data-Dependent Jitter (Rev. A)
    PDF, 275 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Jitter is a phenomenon troubling many designers of high-speed interfaces. It reduces available timingmargin, limits transmission distance between a transmitter and a receiver, and increases system cost bydemanding better performing and more expensive interconnects. LVDS interfaces are not spared fromthese ill effects as they now operate at bit rates exceeding the 3 Gbps mark. Texas Instrumen
Серия: DS25BR120 (1)
  • DS25BR120TSD/NOPB
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments DS25BR120TSD/NOPB
