Datasheet Texas Instruments DS25CP102TSQ/NOPB — Даташит
СерияDS25CP102
МодельDS25CP102TSQ/NOPB
Коммутационный коммутатор LVDS 3,125 Гбит/с 2X2 с предыскажением передачи и выравниванием приема 16-WQFN от -40 до 85
3.125 Gbps 2X2 LVDS Crosspoint sw w/ Xmit Pre-Emphasis & Receive Equalization datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 4 мар 2013
Pin16
Package TypeRGH
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
CarrierSMALL T&R
Маркировка2C102SQ
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
ESD HBM8 kV
FunctionCrosspoint
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 16 mm2: 4 x 4(WQFN) PKG
  • Evaluation Modules & Boards: DS25CP102EVK
    3.125 Gbps 2x2 LVDS Crosspoint Switch Evaluation Board
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • AN-1957 LVDS Signal Conditioners Reduce Data-Dependent Jitter (Rev. A)
    PDF, 275 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Jitter is a phenomenon troubling many designers of high-speed interfaces. It reduces available timingmargin, limits transmission distance between a transmitter and a receiver, and increases system cost bydemanding better performing and more expensive interconnects. LVDS interfaces are not spared fromthese ill effects as they now operate at bit rates exceeding the 3 Gbps mark. Texas Instrumen
Серия: DS25CP102 (1)
  • DS25CP102TSQ/NOPB
  • Semiconductors > Interface > SDI > SDI Cable Equalizers, Drivers, Reclockers, and Cross-Points
На английском языке: Datasheet Texas Instruments DS25CP102TSQ/NOPB
