Datasheet Texas Instruments DS25CP104ATSQX/NOPB — Даташит
СерияDS25CP104A
МодельDS25CP104ATSQX/NOPB
Коммутационный коммутатор LVDS 3,125 Гбит/с 4x4 с предыскажением Tx и выравниванием Rx 40-WQFN от -40 до 85
DS25CP104A/CP114 3.125 Gbps 4x4 LVDS Xpoint Sw w/Xmit Pre-Emp & Receive Equal datasheet
PDF, 876 Кб, Версия: C, Файл опубликован: 4 мар 2013
Pin40
Package TypeRTA
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Маркировка2CP104AS
Width (мм)6
Length (мм)6
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
ESD HBM8 kV
FunctionCrosspoint
Package GroupWQFN
Package Size: mm2:W x L40WQFN: 36 mm2: 6 x 6(WQFN) PKG
  • Triple Rate SDI IP FPGA Resource Utilization on SDXILEVK/AES-EXP-SDI-G Ref Dsgn (Rev. A)
    PDF, 50 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Texas Instruments triple rate (SD/HD/3G) SDI demonstration board showcases the LMH0340 serializer,LMH0341 deserializer, LMH0344 equalizer, LMH1981 sync separator, LMH1982 clock generator withgenlock and the DS25CP104 cross-point switch. There are many advantages to using the TexasInstruments chipset that include superior performance, reduced cost using inexpensive FPGAs such asthe Xilinx S
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • AN-1957 LVDS Signal Conditioners Reduce Data-Dependent Jitter (Rev. A)
    PDF, 275 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Jitter is a phenomenon troubling many designers of high-speed interfaces. It reduces available timingmargin, limits transmission distance between a transmitter and a receiver, and increases system cost bydemanding better performing and more expensive interconnects. LVDS interfaces are not spared fromthese ill effects as they now operate at bit rates exceeding the 3 Gbps mark. Texas Instrumen
  • A 3 Gbps SDI Connectivity Solution Supporting Uncompressed 1080p60 Video
    PDF, 2.9 Мб, Файл опубликован: 18 мар 2008
  • DS25CP104 in 3G SDI Router Application
    PDF, 770 Кб, Файл опубликован: 20 авг 2008
Серия: DS25CP104A (2)
  • Semiconductors > Interface > SDI > SDI Cable Equalizers, Drivers, Reclockers, and Cross-Points
На английском языке: Datasheet Texas Instruments DS25CP104ATSQX/NOPB
