Datasheet Texas Instruments 5962-7802005MFA — Даташит
СерияDS26F32MQML
Модель5962-7802005MFA
Приемники с четырьмя дифференциальными линиями 16-CFP от -55 до 125
DS26F32MQML Quad Differential Line Receivers datasheet
PDF, 429 Кб, Версия: A, Файл опубликован: 15 апр 2013
10 предложений от 9 поставщиков
Чип интерфейса, Quad Receiver RS-422/RS-423 16Pin CPAK Rail
Элитан
5962-7802005MFA
15 400 ₽
5962-7802005MFA
5962-7802005MFA
LifeElectronics
5962-7802005MFA
Pin16
Package TypeNAD
Industry STD TermCFP
JEDEC CodeR-CDFP-F
Package QTY19
Width (мм)6.35
Length (мм)9.906
Thickness (мм)1.88
Max Height (мм)2.032
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
RoHSSee ti.com
  • AN-903 A Comparison of Differential Termination Techniques (Rev. B)
    PDF, 279 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this application report is to remove some of the confusion that may surround signal termination. This discussion will focus attention upon signal termination only as it applies to differential data transmission over twisted pair cable. Common differential signal termination techniques will be presented and the advantages and disadvantages of each will be discussed.
  • Semiconductors > Space & High Reliability > Interface Products > Other Interface Products > Differential Driver/Receiver (non RS422/485)
59627802005MFA, 5962 7802005MFA
На английском языке: Datasheet Texas Instruments 5962-7802005MFA
