Datasheet Texas Instruments 5962-7802005M2A — Даташит
СерияDS26F32MQML
Модель5962-7802005M2A
Приемники с четырьмя дифференциальными линиями 20-LCCC от -55 до 125
DS26F32MQML Quad Differential Line Receivers datasheet
PDF, 429 Кб, Версия: A, Файл опубликован: 15 апр 2013
Микросхема Логический чип, Quad Receiver RS-422/RS-423 20Pin CLLCC Rail
5962-7802005M2A
4 035 ₽
5962-7802005M2A
9 147 ₽
Элитан
5962-7802005M2A
10 077 ₽
5962-7802005M2A
Pin20
Package TypeNAJ
Industry STD TermLCCC
JEDEC CodeS-CLCC-N
Package QTY50
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.753
Max Height (мм)1.905
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
RoHSSee ti.com
  • AN-903 A Comparison of Differential Termination Techniques (Rev. B)
    PDF, 279 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this application report is to remove some of the confusion that may surround signal termination. This discussion will focus attention upon signal termination only as it applies to differential data transmission over twisted pair cable. Common differential signal termination techniques will be presented and the advantages and disadvantages of each will be discussed.
  • Semiconductors > Space & High Reliability > Interface Products > Other Interface Products > Differential Driver/Receiver (non RS422/485)
59627802005M2A, 5962 7802005M2A
На английском языке: Datasheet Texas Instruments 5962-7802005M2A
