Datasheet Texas Instruments DS40MB200SQ/NOPB — Даташит
СерияDS40MB200
МодельDS40MB200SQ/NOPB
Двойной мультиплексор/буфер CML 4,0 Гбит/с 2:1/1:2 с предыскажением передачи и коррекцией приема 48-WQFN от -40 до 85
DS40MB200 Dual 4-Gbps 2:1/1:2 CML MUX/Buffer With Transmit Pre-Emphasis and Receive Equalization datasheet
PDF, 1.4 Мб, Версия: J, Файл опубликован: 14 окт 2015
Pin48
Package TypeNJU
Industry STD TermWQFN
JEDEC CodeS-PQSO-N
Package QTY250
CarrierSMALL T&R
Маркировка40MB200
Width (мм)7
Length (мм)7
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Device TypeBuffer
ESD HBM6 kV
FunctionMux Buffer
ICC(Max)289 мА
Input SignalCML
No. of Rx2,4
No. of Tx2,4
Output SignalCML
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Signaling Rate4000 Mbps
  • Driving Signals Over XAUI Backplanes Using DS42MB100, DS40MB200, or DS42BR400 (Rev. B)
    PDF, 33.4 Мб, Версия: B, Файл опубликован: 26 апр 2013
    This application report demonstrates how TI’s DS42MB100, DS40MB200, and DS42BR400 equalize XAUI backplane FR4 traces and reduce data dependent jitter to within XAUI specifications.
  • Enabling Redundancy in Multi-Gigabit Links w/DS40MB200 Mux/Buffer (Rev. A)
    PDF, 3.5 Мб, Версия: A, Файл опубликован: 26 апр 2013
    The DS40MB200 is a new signal conditioning mux/buffer in TI’s high-speed product portfolio. It enables redundancy and acts as a repeater in high-speed backplanes and cables. It features programmable pre-emphasis and fixed input equalization, enabling error free data links to 4 Gbps. It can also be used as a signal conditioning driver to provide equalization to FR4 board traces as well as cables, s
  • Setting Pre-Empha Level for DS40MB200 Dual 4Gb/s Mux/Buffer (Rev. C)
    PDF, 1.4 Мб, Версия: C, Файл опубликован: 26 апр 2013
    The DS40MB200 is a dual 2:1 multiplexer and 1:2 fan-out repeater designed to support redundancy and extending copper backplane to data rates up to 4 Gb/s. With input equalization and output pre-emphasis, the DS40MB200 is capable of compensating attenuation distortion and reducing deterministic jitter caused by bandwidth-limited transmission lines. This application report outlines the methods to se
  • AN-1398 Printed Circuit Board Design Techniques for DS40MB200 (Rev. A)
    PDF, 144 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The high speed, high gain and fast edge rate attributes of any high-speed circuit requires you to use the high-speed printed circuit board (PCB) techniques to achieve good performance. This application report outlines the techniques to achieve this goal.
Серия: DS40MB200 (1)
  • DS40MB200SQ/NOPB
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments DS40MB200SQ/NOPB
