Datasheet Texas Instruments DS80PCI102SQE/NOPB — Даташит
СерияDS80PCI102
МодельDS80PCI102SQE/NOPB
2,5 Гбит/с/5,0 Гбит/с/8,0 Гбит/с 1-полосный повторитель PCI Express с эквалайзером и деакцентом 24-WQFN от -40 до 85
DS80PCI102 2.5-Gbps / 5.0-Gbps / 8.0-Gbps 1-Lane PCI-Express Repeater With Equalization and De-Emphasis datasheet
PDF, 3.7 Мб, Версия: G, Файл опубликован: 24 авг 2015
Pin24
Package TypeRTW
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаPCI102
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Device TypeRedriver
IN SigConEQ
Input CompatibilityAC-Coupled,CML
Количество каналов2
OUT SigConDE
Output CompatibilityAC-Coupled,CML
Package GroupWQFN
ProtocolsPCIe1,PCIe2,PCIe3,sRIO,General Purpose
Speed(Max)8 Gbps
SupplyVoltage2.5,3.3 Volt
  • Evaluation Modules & Boards: DS80PCI102EVK
    DS80PCI102 SMA Evaluation Kit
  • Understanding EEPROM Programming for High Speed Repeaters and Mux Buffers
    PDF, 317 Кб, Файл опубликован: 9 окт 2014
    System designers often use EEPROM (Electrically Erasable Programmable Read-Only Memory) to program a set of customized high speed repeater and mux buffer start-up settings that are different from the default. Using the information here will make repeater EEPROM configuration and programming easy to implement and understand. This application note addresses SMBus-to-EEPROM mapping for 2-channel repe
Серия: DS80PCI102 (2)
  • Semiconductors > Interface > PCIe/SAS/SATA > Retimers, Redrivers and Switches/Muxes
На английском языке: Datasheet Texas Instruments DS80PCI102SQE/NOPB
