Datasheet Texas Instruments DS80PCI810NJYR — Даташит
СерияDS80PCI810
МодельDS80PCI810NJYR
DS80PCI810 Маломощный 8-канальный линейный повторитель 8 Гбит/с с выравниванием 54-WQFN от -40 до 85
DS80PCI810 Low-Power 8 Gbps 8-Channel Linear Repeater datasheet
PDF, 1.8 Мб, Версия: A, Файл опубликован: 6 фев 2015
Pin54
Package TypeNJY
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY2000
Маркировка80PCI810A0
Width (мм)5.5
Length (мм)10
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Device TypeRedriver
IN SigConEQ
Input CompatibilityAC-Coupled,CML
Количество каналов8
OUT SigConLinear CML Driver
Output CompatibilityAC-Coupled,CML
Package GroupWQFN
ProtocolsPCIe1,PCIe2,PCIe3
Speed(Max)8 Gbps
SupplyVoltage2.5,3.3 Volt
  • Evaluation Modules & Boards: DS80PCI810EVM
    DS80PCI810 Evaluation Module
  • Advanced Linear Repeater Used in PCIe 3.0 Add-in Card Compliance Environment
    PDF, 689 Кб, Файл опубликован: 2 окт 2014
    This report summarizes the results of PCIe Gen 3.0 add-in card compliance testing using TI’s low-power 12.5 Gbps 8-channel advanced linear repeater. The advanced linear repeater is placed in a mid-channel configuration between a PCIe Gen 3.0 graphics card and a compliance base board (CBB) and tested for jitter, eye mask, and TX preset compliance. The results demonstrate the excellent signal condit
  • Advanced linear equalization in multi-gigabit systems
    PDF, 870 Кб, Файл опубликован: 28 апр 2015
  • Channel Tuning Made Easy Using Linear Repeaters for 10G and 12G Applications
    PDF, 3.4 Мб, Файл опубликован: 20 янв 2015
    This report demonstrates the benefits of using Texas Instruments Linear Redrivers to simplify the process of channel tuning and improve system margins. Test results of the DS125BR820 linear redriver operating in various pre-channel and post-channel conditions are presented and show improvements in channel conditions in terms of transmitter pre- and post-cursor error-free operat
  • Analog Applications Journal 2Q 2015
    PDF, 2.5 Мб, Файл опубликован: 28 апр 2015
  • Understanding EEPROM Programming for High Speed Repeaters and Mux Buffers
    PDF, 317 Кб, Файл опубликован: 9 окт 2014
    System designers often use EEPROM (Electrically Erasable Programmable Read-Only Memory) to program a set of customized high speed repeater and mux buffer start-up settings that are different from the default. Using the information here will make repeater EEPROM configuration and programming easy to implement and understand. This application note addresses SMBus-to-EEPROM mapping for 2-channel repe
Серия: DS80PCI810 (2)
  • Semiconductors > Interface > PCIe/SAS/SATA > Retimers, Redrivers and Switches/Muxes
На английском языке: Datasheet Texas Instruments DS80PCI810NJYR
