Datasheet Texas Instruments DS90UB913ATRTVRQ1 — Даташит
СерияDS90UB913A-Q1
МодельDS90UB913ATRTVRQ1
25–100 МГц, 10/12 бит FPD-Link III, СЕРИАЛАЙЗЕР 32-WQFN, от -40 до 105
DS90UB913A-Q1 25-MHz to 100-MHz 10/12-Bit FPD-Link III Serializer datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 29 окт 2016
Pin32
Package TypeRTV
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаUB913AQ
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth12 bpp
DiagnosticsBIST
EMI Reduction-
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityFPD-Link III LVDS
Package GroupWQFN
Package Size: mm2:W x L32WQFN: 25 mm2: 5 x 5(WQFN) PKG
Pixel Clock Min25 МГц
Pixel Clock(Max)100 МГц
RatingAutomotive
Signal Conditioning-
Special FeaturesCRC,I2C Config
Total Throughput1400 Mbps
  • Evaluation Modules & Boards: DS90UB913A-CXEVM
    DS90UB913A-CXEVM: FPD-Link III Serializer Evaluation Module
  • Sending Power over Coax in DS90UB913A Designs
    PDF, 153 Кб, Файл опубликован: 26 июн 2014
    The DS90UB913A was designed as a serializer to support automotive camera designs. Automotive cameras are often located in remote positions such as bumpers or trunk lids, and a major component of the system cost is the wiring. For this reason it is desirable to minimize the wiring to the camera. FPD III systems allow the video data, along with a bidirectional control channel, an
  • Cable Requirements for the DS90UB913A and DS90UB914A
    PDF, 41 Кб, Файл опубликован: 14 окт 2014
    The DS90UB913A and DS90UB914A chipset transports serialized video data over coaxial cables. A variety of cable assemblies meeting this generic description are available on the market, and not all perform equally. This document defines the cable characteristics required to properly support the high speed serial data transfer from a DS90UB913A serializer to a DS90UB914A deserializer. Three key pa
  • Ten tips for successfully designing with automotive EMC/EMI requirements
    PDF, 380 Кб, Файл опубликован: 24 июл 2015
  • I2C Communication over DS90UB913/4 FPD Link-III with BCC
    PDF, 4.9 Мб, Файл опубликован: 22 апр 2013
    This application note describes I2C communication between DS90UB913/914 devices through the FPDLinkIII bidirectional control channel (referred as BCC). The low latency BCC interface allows the masterI2C device to remotely communicate with peripherals across the serial link.
  • Analog Applications Journal 3Q 2015
    PDF, 7.1 Мб, Файл опубликован: 24 июл 2015
Серия: DS90UB913A-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Camera SerDes
На английском языке: Datasheet Texas Instruments DS90UB913ATRTVRQ1
