Datasheet Texas Instruments DS90UB914ATRHSRQ1 — Даташит
СерияDS90UB914A-Q1
МодельDS90UB914ATRHSRQ1
Десериализатор FPD-Link III, 10/12 бит, 25–100 МГц, 48-WQFN, от -40 до 105
DS90UB914A-Q1 25-MHz to 100-MHz 10/12-Bit FPD-Link III Deserializer datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 29 окт 2016
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаUB914AQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth12 bpp
DiagnosticsBIST
EMI ReductionSSCG,Staggered Outputs
FunctionDeserializer
Input CompatibilityFPD-Link III LVDS
Output CompatibilityLVCMOS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min25 МГц
Pixel Clock(Max)100 МГц
RatingAutomotive
Signal ConditioningAdaptive Equalizer
Special FeaturesFPD-Link III Coax
Total Throughput1400 Mbps
  • Evaluation Modules & Boards: DS90UB914A-CXEVM
    DS90UB914A-CXEVM: FPD-Link III Deserializer Evaluation Module
  • Cable Requirements for the DS90UB913A and DS90UB914A
    PDF, 41 Кб, Файл опубликован: 14 окт 2014
    The DS90UB913A and DS90UB914A chipset transports serialized video data over coaxial cables. A variety of cable assemblies meeting this generic description are available on the market, and not all perform equally. This document defines the cable characteristics required to properly support the high speed serial data transfer from a DS90UB913A serializer to a DS90UB914A deserializer. Three key pa
  • Ten tips for successfully designing with automotive EMC/EMI requirements
    PDF, 380 Кб, Файл опубликован: 24 июл 2015
  • I2C Communication over DS90UB913/4 FPD Link-III with BCC
    PDF, 4.9 Мб, Файл опубликован: 22 апр 2013
    This application note describes I2C communication between DS90UB913/914 devices through the FPDLinkIII bidirectional control channel (referred as BCC). The low latency BCC interface allows the masterI2C device to remotely communicate with peripherals across the serial link.
  • Analog Applications Journal 3Q 2015
    PDF, 7.1 Мб, Файл опубликован: 24 июл 2015
Серия: DS90UB914A-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Camera SerDes
На английском языке: Datasheet Texas Instruments DS90UB914ATRHSRQ1
