Datasheet Texas Instruments DS90UB914QSQ/NOPB — Даташит
СерияDS90UB914Q-Q1
МодельDS90UB914QSQ/NOPB
DS90UB913Q/4Q 10–100 МГц 10/12 бит FPD-Link III SER/DES 48-WQFN от -40 до 105
DS90UB91xQ-Q1 10- to 100-MHz, 10- and 12-Bit DC-Balanced FPD-Link III Serializer and Deserializer With Bidirectional Control Channel datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 31 июл 2015
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаUB914QSQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth12 bpp
DiagnosticsBIST
EMI ReductionSSCG,Staggered Outputs
FunctionDeserializer
Input CompatibilityFPD-Link III LVDS
Output CompatibilityLVCMOS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min10 МГц
Pixel Clock(Max)100 МГц
RatingAutomotive
Signal ConditioningAdaptive Equalizer
Special Features2:1 input multiplexer,CRC,I2C Config
Total Throughput1400 Mbps
  • Evaluation Modules & Boards: ALP
    Analog LaunchPad Framework Utility
  • I2C Communication over DS90UB913/4 FPD Link-III with BCC
    PDF, 4.9 Мб, Файл опубликован: 22 апр 2013
    This application note describes I2C communication between DS90UB913/914 devices through the FPDLinkIII bidirectional control channel (referred as BCC). The low latency BCC interface allows the masterI2C device to remotely communicate with peripherals across the serial link.
Серия: DS90UB914Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Camera SerDes
На английском языке: Datasheet Texas Instruments DS90UB914QSQ/NOPB
