Datasheet Texas Instruments DS90UB925QSQX/NOPB — Даташит
СерияDS90UB925Q-Q1
МодельDS90UB925QSQX/NOPB
Сериализатор FPD-Link III, 24 бита, 5–85 МГц, с двунаправленным каналом управления 48-WQFN от -40 до 105
DS90UB925Q-Q1 5 to 85 MHz 24-Bit Color FPD-Link III Serializer With Bidirectional Control Channel datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 23 окт 2014
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаUB925QSQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST
EMI ReductionSSC Compatible
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityFPD-Link III LVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)85 МГц
RatingAutomotive
Signal Conditioning-
Special FeaturesI2C Config,I2S Audio
Total Throughput2975 Mbps
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Using the I2S Audio Interface of DS90Ux92x FPD-Link III Devices
    PDF, 121 Кб, Файл опубликован: 4 май 2013
    I2S is a standard protocol for transmitting two channels (stereo) Pulse Code Modulated digital data over a3-wire serial bus.Advanced automotive systems require transport of multiple audio data sources, such as mobile devices,Navigation systems, Infotainment, security, or gaming consoles, to speakers located throughout thevehicle. Also, surround sound systems requiring multiple audio data
  • I2C Communication Over FPD-Link III with Bidirectional Control Channel (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note describes communication between devices using the FPD-Link III SerDes with a bidirectional control channel using I2C. The low latency bidirectional control interface allows the master I2C device to remotely control peripherals across the serial link.
  • Enabling GPIOs in DS90UB925 and DS90UB926
    PDF, 293 Кб, Файл опубликован: 10 ноя 2015
    The 24-bit RGB interface is widely used in automotive infotainment. In addition to the 24-bit RGB interface, separate slower speed control signals are also needed. The DS90UB925 and DS90UB926 have additional pins for such applications with the additional control signals. Examples of control signals needed to be sent from the H/U (head unit) to display are display enable, display reset, and backlig
Серия: DS90UB925Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UB925QSQX/NOPB
