Datasheet Texas Instruments DS90UB926QSQX/NOPB — Даташит
СерияDS90UB926Q-Q1
МодельDS90UB926QSQX/NOPB
24-битный цветной десериализатор FPD-Link III 5–85 МГц с двунаправленным каналом управления 60-WQFN от -40 до 105
DS90UB926Q-Q1 5- to 85-MHz, 24-Bit Color FPD-Link III Deserializer With Bidirectional Control Channel datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 3 авг 2017
Pin60
Package TypeNKB
Industry STD TermWQFN
JEDEC CodeS-PQSO-N
Package QTY2000
МаркировкаUB926QSQ
Width (мм)9
Length (мм)9
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST
EMI ReductionSSCG,Staggered Outputs
FunctionDeserializer
Input CompatibilityFPD-Link III LVDS
Output CompatibilityLVCMOS
Package GroupWQFN
Package Size: mm2:W x L60WQFN: 81 mm2: 9 x 9(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)85 МГц
RatingAutomotive
Signal ConditioningAdaptive Equalizer
Special FeaturesI2C Config,I2S Audio
Total Throughput2550 Mbps
  • Evaluation Modules & Boards: DS90UB928QEVM
    DS90UB928QEVM FPD-Link III Deserializer Evaluation Module
  • Evaluation Modules & Boards: DS90UB926QSEVB
    DS90UB926Q Evaluation Module
  • Evaluation Modules & Boards: DS90UH928QEVM
    DS90UH928QEVM FPD-Link III Deserializer Evaluation Module
  • Using the I2S Audio Interface of DS90Ux92x FPD-Link III Devices
    PDF, 121 Кб, Файл опубликован: 4 май 2013
    I2S is a standard protocol for transmitting two channels (stereo) Pulse Code Modulated digital data over a3-wire serial bus.Advanced automotive systems require transport of multiple audio data sources, such as mobile devices,Navigation systems, Infotainment, security, or gaming consoles, to speakers located throughout thevehicle. Also, surround sound systems requiring multiple audio data
  • I2C Communication Over FPD-Link III with Bidirectional Control Channel (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note describes communication between devices using the FPD-Link III SerDes with a bidirectional control channel using I2C. The low latency bidirectional control interface allows the master I2C device to remotely control peripherals across the serial link.
  • Enabling GPIOs in DS90UB925 and DS90UB926
    PDF, 293 Кб, Файл опубликован: 10 ноя 2015
    The 24-bit RGB interface is widely used in automotive infotainment. In addition to the 24-bit RGB interface, separate slower speed control signals are also needed. The DS90UB925 and DS90UB926 have additional pins for such applications with the additional control signals. Examples of control signals needed to be sent from the H/U (head unit) to display are display enable, display reset, and backlig
Серия: DS90UB926Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UB926QSQX/NOPB
