Datasheet Texas Instruments DS90UB928QSQ/NOPB — Даташит
СерияDS90UB928Q-Q1
МодельDS90UB928QSQ/NOPB
Десериализатор FPD-Link III с двунаправленным каналом управления 48-WQFN от -40 до 105
DS90UB928Q-Q1 5 MHz to 85 MHz 24-bit Color FPD-Link III to FPD-Link Deserializer With Bidirectional Control Channel datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 26 июл 2016
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаUB928QSQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST
EMI ReductionLVDS
FunctionDeserializer
Input CompatibilityFPD-Link III LVDS
Output CompatibilityLVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)85 МГц
RatingAutomotive
Signal ConditioningAdaptive Equalizer
Special FeaturesDedicated GPIO,I2C Config,I2S Surround Audio,Pattern Generator
Total Throughput2550 Mbps
  • Evaluation Modules & Boards: DS90UB928QEVM
    DS90UB928QEVM FPD-Link III Deserializer Evaluation Module
  • AN-2198 Exploring Int Test Patt Gen Feat of 720p FPD-Link III Devices (Rev. C)
    PDF, 105 Кб, Версия: C, Файл опубликован: 28 июн 2013
    This application report describes the pattern generator feature of the FPD-Link III 720p devices(DS90Ux92xQ), including the relevant control registers. It also provides several examples for accessingthese control registers to meet custom display application requirements.
  • Using the I2S Audio Interface of DS90Ux92x FPD-Link III Devices
    PDF, 121 Кб, Файл опубликован: 4 май 2013
    I2S is a standard protocol for transmitting two channels (stereo) Pulse Code Modulated digital data over a3-wire serial bus.Advanced automotive systems require transport of multiple audio data sources, such as mobile devices,Navigation systems, Infotainment, security, or gaming consoles, to speakers located throughout thevehicle. Also, surround sound systems requiring multiple audio data
  • I2C Communication Over FPD-Link III with Bidirectional Control Channel (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note describes communication between devices using the FPD-Link III SerDes with a bidirectional control channel using I2C. The low latency bidirectional control interface allows the master I2C device to remotely control peripherals across the serial link.
Серия: DS90UB928Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UB928QSQ/NOPB
