Datasheet Texas Instruments DS90UH925QSQX/NOPB — Даташит
СерияDS90UH925Q-Q1
МодельDS90UH925QSQX/NOPB
Сериализатор FPD-Link III, 24 бита, 5–85 МГц, с HDCP 48-WQFN от -40 до 105
DS90UH925Q-Q1 720p 24-bit Color FPD-Link III Serializer with HDCP datasheet
PDF, 1.3 Мб, Версия: J, Файл опубликован: 7 ноя 2014
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаUH925QSQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST
EMI ReductionSSC Compatible
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityFPD-Link III LVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)85 МГц
RatingAutomotive
Signal Conditioning-
Special FeaturesHDCP,I2C Config,I2S Audio
Total Throughput2975 Mbps
  • Evaluation Modules & Boards: DS90UH925QSEVB
    DS90UH925QSEVB Evaluation Board
  • AN-2198 Exploring Int Test Patt Gen Feat of 720p FPD-Link III Devices (Rev. C)
    PDF, 105 Кб, Версия: C, Файл опубликован: 28 июн 2013
    This application report describes the pattern generator feature of the FPD-Link III 720p devices(DS90Ux92xQ), including the relevant control registers. It also provides several examples for accessingthese control registers to meet custom display application requirements.
  • Using the I2S Audio Interface of DS90Ux92x FPD-Link III Devices
    PDF, 121 Кб, Файл опубликован: 4 май 2013
    I2S is a standard protocol for transmitting two channels (stereo) Pulse Code Modulated digital data over a3-wire serial bus.Advanced automotive systems require transport of multiple audio data sources, such as mobile devices,Navigation systems, Infotainment, security, or gaming consoles, to speakers located throughout thevehicle. Also, surround sound systems requiring multiple audio data
  • I2C Communication Over FPD-Link III with Bidirectional Control Channel (Rev. A)
    PDF, 53 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note describes communication between devices using the FPD-Link III SerDes with a bidirectional control channel using I2C. The low latency bidirectional control interface allows the master I2C device to remotely control peripherals across the serial link.
  • Enabling GPIOs in DS90UB925 and DS90UB926
    PDF, 293 Кб, Файл опубликован: 10 ноя 2015
    The 24-bit RGB interface is widely used in automotive infotainment. In addition to the 24-bit RGB interface, separate slower speed control signals are also needed. The DS90UB925 and DS90UB926 have additional pins for such applications with the additional control signals. Examples of control signals needed to be sent from the H/U (head unit) to display are display enable, display reset, and backlig
Серия: DS90UH925Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UH925QSQX/NOPB
