Datasheet Texas Instruments DS90UR124IVS/NOPB — Даташит
СерияDS90UR124
МодельDS90UR124IVS/NOPB
24-битный десериализатор FPD-Link II, балансный по постоянному току, 5–43 МГц, 64-TQFP от -40 до 105
DS90URxxx-Q1 5-MHz to 43-MHz DC-Balanced 24-Bit FPD-Link II Serializer and Deserializer Chipset datasheet
PDF, 1.4 Мб, Версия: O, Файл опубликован: 29 апр 2015
Pin6464
Package TypePAGPAG
Industry STD TermTQFPTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY160160
МаркировкаIVSDS90UR124
Width (мм)1010
Length (мм)1010
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Color Depth18 bpp
DiagnosticsBIST
EMI ReductionAdjustable Progressive Turn On (PTO),Slew Rate Control
FunctionDeserializer
Input CompatibilityFPD-Link II LVDS
Output CompatibilityLVCMOS
Package GroupTQFP
Package Size: mm2:W x L64TQFP: 144 mm2: 12 x 12(TQFP) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)43 МГц
Signal Conditioning-
Special Features-
Total Throughput1032 Mbps
  • Evaluation Modules & Boards: SERDESUR-43USB
    Evaluation Kit for DS90UR241 DS90UR124 Serializer and Deserializer Chipset
  • AN-2068 DS90UR241/124 Spread Spectrum Tolerance Support (Rev. B)
    PDF, 70 Кб, Версия: B, Файл опубликован: 26 апр 2013
    Compliance to EMI limits is often a challenge. Spread spectrum clocking is commonly used to minimize EMI. The effect of modulating periodic signals, both clock and data, reduces the peak emissions by spreading the energy over a range of frequencies. The DS90UR241 and DS90UR124 chipset allows the use of spread spectrum clock and data inputs. The following is a discussion of spread spectrum clock ch
  • AN-1807 FPD-Link II Display SerDes Overview (Rev. B)
    PDF, 45 Кб, Версия: B, Файл опубликован: 26 апр 2013
    TI’s FPD-Link II family of embedded clock LVDS SerDes provide enhanced features, and improved signal quality over prior generations of FPD-Link SerDes devices for Display applications. FPD-Link Chipsets serialized the wide parallel RGB buses down to 4 or 5 pairs of LVDS signaling depending upon the chipset. 18-bit RGB was serialized to three LVDS data lines and a LVDS clock, while 24-bit RGB was s
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • Extending the Reach of a FPD-Link II Interface with Cable Drivers and Equalizers (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 26 апр 2013
    TI's family of embedded clock LVDS SER/DES (FPD-link II) provides a 2-wire serial interface for displayapplications up to distances of 10 meters.
  • DS15BA101 & DS15EA101 Enable Long Reach Applications for Embedded Clock SER/DES (Rev. E)
    PDF, 170 Кб, Версия: E, Файл опубликован: 29 апр 2013
    Reduction in system size, increase in system performance and savings in system cost are valuablebenefits that SER/DES devices (Serializers and Deserializers) bring to many system designers. Thesebenefits are the reason why SER/DES are integral pieces of many of today’s high-speed systems.One of the design constraints for these systems is the maximum transmission distance between a serializer
Серия: DS90UR124 (2)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UR124IVS/NOPB
