Datasheet Texas Instruments DS90UR905QSQ/NOPB — Даташит
СерияDS90UR905Q-Q1
МодельDS90UR905QSQ/NOPB
Сериализатор FPD-Link II, 24 бита, 5–65 МГц, 48-WQFN, от -40 до 105
DS90UR90xQ-Q1 5- to 65-MHz, 24-bit Color FPD-Link II Serializer and Deserializer datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 31 июл 2015
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаUR905QSQ
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST,I2C Bus
EMI ReductionSSC Compatible
FunctionSerializer
Input CompatibilityLVCMOS
Output CompatibilityFPD-Link II LVDS
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)65 МГц
RatingAutomotive
Signal ConditioningDe-Emphasis,VOD Select
Special Features1.8V or 3.3V VDDIO,I2C Config
Total Throughput1560 Mbps
  • AN-1807 FPD-Link II Display SerDes Overview (Rev. B)
    PDF, 45 Кб, Версия: B, Файл опубликован: 26 апр 2013
    TI’s FPD-Link II family of embedded clock LVDS SerDes provide enhanced features, and improved signal quality over prior generations of FPD-Link SerDes devices for Display applications. FPD-Link Chipsets serialized the wide parallel RGB buses down to 4 or 5 pairs of LVDS signaling depending upon the chipset. 18-bit RGB was serialized to three LVDS data lines and a LVDS clock, while 24-bit RGB was s
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • Extending the Reach of a FPD-Link II Interface with Cable Drivers and Equalizers (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 26 апр 2013
    TI's family of embedded clock LVDS SER/DES (FPD-link II) provides a 2-wire serial interface for displayapplications up to distances of 10 meters.
Серия: DS90UR905Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UR905QSQ/NOPB
