Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DS90UR906QSQX/NOPB — Даташит
СерияDS90UR906Q-Q1
МодельDS90UR906QSQX/NOPB
Десериализатор Color FPD-Link II, 5–65 МГц, 24 бита, 60-WQFN, от -40 до 105
DS90UR90xQ-Q1 5- to 65-MHz, 24-bit Color FPD-Link II Serializer and Deserializer datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 31 июл 2015
Pin60
Package TypeNKB
Industry STD TermWQFN
JEDEC CodeS-PQSO-N
Package QTY2000
МаркировкаUR906QSQ
Width (мм)9
Length (мм)9
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Color Depth24 bpp
DiagnosticsBIST,I2C Bus
EMI ReductionSSCG,RDS,Progressive Turn On (PTO)
FunctionDeserializer
Input CompatibilityFPD-Link II LVDS
Output CompatibilityLVCMOS
Package GroupWQFN
Package Size: mm2:W x L60WQFN: 81 mm2: 9 x 9(WQFN) PKG
Pixel Clock Min5 МГц
Pixel Clock(Max)65 МГц
RatingAutomotive
Signal ConditioningEqualizer
Special Features1.8V or 3.3V VDDIO,I2C Config
Total Throughput1560 Mbps
  • AN-1807 FPD-Link II Display SerDes Overview (Rev. B)
    PDF, 45 Кб, Версия: B, Файл опубликован: 26 апр 2013
    TI’s FPD-Link II family of embedded clock LVDS SerDes provide enhanced features, and improved signal quality over prior generations of FPD-Link SerDes devices for Display applications. FPD-Link Chipsets serialized the wide parallel RGB buses down to 4 or 5 pairs of LVDS signaling depending upon the chipset. 18-bit RGB was serialized to three LVDS data lines and a LVDS clock, while 24-bit RGB was s
  • LVDS Repeaters and Crosspoints Extend the Reach of FPD-Link II Interfaces (Rev. A)
    PDF, 101 Кб, Версия: A, Файл опубликован: 29 апр 2013
    This application note introduces Texas Instrument’s LVDS devices with built-in pre-emphasis andequalization circuits, recommends when it makes sense to employ them with the FPD-Link II SER/DES,shows how to optimally interface them to the SER/DES, and discusses distance gains that may berealized with their signal enhancing functions.
  • Extending the Reach of a FPD-Link II Interface with Cable Drivers and Equalizers (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 26 апр 2013
    TI's family of embedded clock LVDS SER/DES (FPD-link II) provides a 2-wire serial interface for displayapplications up to distances of 10 meters.
Серия: DS90UR906Q-Q1 (3)
  • Semiconductors > Interface > FPD-Link SerDes > Display SerDes
На английском языке: Datasheet Texas Instruments DS90UR906QSQX/NOPB
