Datasheet Texas Instruments DS91C176TMA — Даташит
СерияDS91C176
МодельDS91C176TMA
Одноканальные трансиверы M-LVDS 100 МГц 8-SOIC от -40 до 85
DS91D176/DS91C176 100 MHz Single Channel M-LVDS Transceivers datasheet
PDF, 1.0 Мб, Версия: L, Файл опубликован: 16 апр 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
Маркировка176MADS91C
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementDS91C176TMA/NOPB
Replacement CodeS
Device TypeTransceiver
ESD HBM8 kV
FunctionTransceiver
ICC(Max)29.5 мА
Input SignalLVTTL,M-LVDS
No. of Rx1
No. of Tx1
Output SignalLVTTL,M-LVDS
ProtocolsM-LVDS
Signaling Rate200 Mbps
RoHSSee ti.com
  • Evaluation Modules & Boards: DS91C176EVK
    RJ45 to SMA Adapter with DS91C176, an M-LVDS Type 2 Transceiver
  • Designing an ATCA Compliant M-LVDS Clock Distribution Network (Rev. B)
    PDF, 276 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report provides a guide to designing ATCA compliant clock distribution networks using M-LVDS devices. The application report consists of a quick description of an ATCA synchronization clock interface, an overview of M-LVDS standard, an extensive discussion on performance of M-LVDS devices in an ATCA backplane and a set of design recommendations and rules that will assist you in bu
Серия: DS91C176 (3)
  • Semiconductors > Interface > LVDS/M-LVDS/PECL > Buffers, Drivers/Receivers and Cross-Points
На английском языке: Datasheet Texas Instruments DS91C176TMA
